need computer/laptop help
Old Dec 30, 2009 | 11:34 PM
blAk mAx's Avatar
my friend has a sony laptop model PCG-4K1L.. he said he dropped it (from bed to carpet) and the screen stopped working.. soon the computer wouldnt start at all... from what i remember he said geek squad told him he would need a new mother board.. does that sound right? if i pull the hard drive how can i link it to my pc to save the files ? thanks
Old Dec 30, 2009 | 11:40 PM
Nightm4re's Avatar
if he needs a new motherboard, he shouldnt lose any of his stuff from his hardrive
also, i dont see how it would have messed up his motherboard... maybe mess up a wire to the screen or something.. but idk, anything is possible
Old Dec 30, 2009 | 11:47 PM
thescreensavers's Avatar
Mr.202?
eh, the screen not working could just be the inverter that powers the monitor, they are sensitive. Now you say its not powering up, it might just be coincidence.
http://www.amazon.com/Sony-VGN-TXN25N-11-1-inch-Processor-Business/dp/B000MQM02I http://www.amazon.com/Sony-VGN-TXN25N-11-1-inch-Processor-Business/dp/B000MQM02I
I believe thats the laptop, he prob paid a pretty penny for it. Its going to cost a lot for Geek squad to get a new mobo and install it. Might see how much sony might offer. Or another shop.
or it might be better just to get a new one.
Have you unplugged all power and battery from the laptop for 30sec+ and plugged it back in? that can fix minor issues. If it hasn't been done.
And yes, all you need is a 2.5inch HD enclosure and you can just plug the hard drive via USB and you'll have full access to all his info, thats if the hard drive didn't take a dump as well, which it should be ok.
Old Dec 31, 2009 | 12:03 AM
blAk mAx's Avatar
he already has a replacement laptop..this happened months ago.. he gave me the laptop recently to see if i could do anything to fix it. it hasnt been able to power on at all since ive had it
Old Dec 31, 2009 | 12:06 AM
Mr.202?
did you try the little trick I said? It will seem to be a paper weight, unless you want to spend 300-500 + to fix. Imo you can get a net book for less then fixing it and will be more powerful. just saying.
But Seems somethings defective.
Old Dec 31, 2009 | 12:21 AM
blAk mAx's Avatar
i think he got an acer to replace it... ive had the battery out for a while and it hasnt started up
Old Dec 31, 2009 | 12:35 AM
Mr.202?
and the plug for the wall? remove all power from it. any how
^ its prob the mobo, its dead if its not powering on at all.
Old Dec 31, 2009 | 08:25 AM
escobar929's Avatar
the mother board is prob dead. take out the hard drive and put it in an enclosure to get the data out, but hard drives tend to also fail after a computer has been dropped. since they are spinning so fast, unless it wasnt really running when it fell
Old Dec 31, 2009 | 10:15 AM
ishiftinheels's Avatar
Teh Redhead Moderator
If you need to take the hard drive out and get the files, I recommend this:
http://www.compusa.com/applications/...746&catid=2785
This is what I'm buying (today, actually, because today is the last day for the listed price) for my macbook. You take the hard drive out & plug it into another computer, pretty simple. I'm not sure if this exact model works for both Mac and Windows, but I think it does.
Edit: I was also quoted between $250 and $500 to "restore" my macbook... My friend who used to work at the Apple store recommended this for me to try first. If I can spend $25 and recover all the old files myself, it's soooo worth it. Tell your friend not to pay that much if he doesn't have to.
Old Dec 31, 2009 | 10:23 AM
escobar929's Avatar
V, if you need any help w/ you mac, let me know.
no way should you have to pay that much for a simple restore, thats BS
Old Dec 31, 2009 | 10:52 AM
Thanks! Not to hijack the thread, but the startup disk is full and it can't read it to boot up. When I turn it on, I get a flashing question mark. My CD drive doesn't work so I can't insert the OSX disk. I'm going to get that hard drive reader thingie today although I probably won't get around to messing with it until the weekend. I'll let you know if it doesn't work. If it doesn't work... I don't know what I'm gonna do because that computer has 3 years of my life on it.
Old Dec 31, 2009 | 12:05 PM
Infinitz's Avatar
or just get an inexpensive external sata adapter (assuming the hard drive is sata) and connect via USB to another computer. Assuming its using the same OS, you should be able to see your files.
http://www.bestbuy.com/site/Rocketfi...sata&cp=1&lp=3
there are much cheaper ones out there that will do the job
^^ That's similar to what I linked above
Old Dec 31, 2009 | 12:08 PM
Infinitz's Avatar
whoops didnt see that
"bows down in shame"
Old Dec 31, 2009 | 12:42 PM
ahaha its otay
