FGC's Hot August Discussions
Old Aug 29, 2011 | 06:46 PM
  #1786
Invalid_User's Avatar
Originally Posted by G35_FTMFW
Got a pair of 255/35/20 nitto 555s for sale 170! 70% tread left
Daddy needs a new glock
Old Aug 29, 2011 | 07:17 PM
  #1787
Sen's Avatar
Sen
Originally Posted by jake_91306
think thats it? I had my alignment done earlier this year.... must be the potholes?
Are you talking about the "lip" around the corner of the tire?
Old Aug 29, 2011 | 07:41 PM
  #1788
Sen's Avatar
Sen
anyone know what the hell this is a symptom of???
Is this on the inside corner? And does it do that around the entire tire? Or does it just bulge in one area?
Old Aug 29, 2011 | 09:30 PM
  #1789
ConradoR's Avatar
It seems like the tire was over-inflated, and kept at a very high psi for a long period of tire and/or several hundred/thousands of miles, specially if the tire was dry rotted (kept in the sun or garaged for months without moving, or both). What psi do you usually keep them at? 34-36psi is usually the recommended for the typical vq35 application, but it can vary slightly. Some tires with soft walls are pumped a little more to compensate and improve handling during turns.
I believe that the reason the "bulge" stops by the sides is because of the reinforcement from the sidewalls, which is keeping it from rising like the rest of the tire.
Check your psi after the car has been parked for a while (to make sure that the air inside isn't expanded from the heat of the tire rolling), and go from there.
Old Aug 29, 2011 | 09:53 PM
  #1790
Sen's Avatar
Sen
Originally Posted by ConradoR
It seems like the tire was over-inflated, and keep at a very high psi for a long period of tire and/or several hundred/thousands of miles, specially is the tire was dry rotted (kept in the sun or garaged for months without moving, or both). What psi do you usually keep them at? 34-36psi is usually the recommended for the typical vq35 application, but it can vary slightly. Some tires with soft walls are pumped a little more to compensate and improve handling during turns.
That's what I was thinking. It didn't seem like abnormal wear, but something wrong with the tire itself. Kinda bizarre, but you're descriptions seem to make a lot of sense. I'm just wondering if damage has been done to the tire already. Last thing you want is sidewall separation at 70+mph.
Old Aug 29, 2011 | 10:34 PM
  #1791
Evil Wayzz's Avatar
Old Aug 29, 2011 | 10:54 PM
  #1792
thescreensavers's Avatar
Mr.202?
Email the manufacturer see what they say
Old Aug 29, 2011 | 10:59 PM
  #1793
HavokGT's Avatar
t1s are the secks.
I got some knock offs tho >_> they still look good
Old Aug 29, 2011 | 11:06 PM
  #1794
HavokGT's Avatar
balloonhands.
price on tien basics and ztube, buddy.
black 07.
i got you bro. you need to paint your calipers red... great theme. paint the rotor hub mounts gloss black so they dont look rusted...then you need to paint a red time attack line around your 18's. then, you need to paint you center caps gloss black but leave the emblem chrome. paint your grille gloss black/ob and leave the lip chrome and the emblem chrome as well. debadge your rear trunk down to your emblem. drop it 1.5 inch and spacers.
You will love it. i promise you. i can invision it in my head.
oh and if you look on the fgc section, theres a meet on s obt at a exhaust shop on a sat morning. i mite attend.
  #1795
SN00P's Avatar
CLUB MODERATOR
My b'day is in a few days woott
Old Aug 29, 2011 | 11:22 PM
  #1796
iamericgee's Avatar
Originally Posted by Evil Wayzz
what the?
Old Aug 29, 2011 | 11:38 PM
  #1797
My Key's Avatar
Yep. Inner shoulder.
it bulges sporadically around the inner shoulder. not continuous.
Air pressure was 36-37 psi's around the whole car. I check it in the morning about once a week to make sure there's no air leakage. I daily the car.
my mechanic said it was a faulty tire with incorrect toe. we were gonna flip the tires but I noticed a crack on that tire that wasn't there when I took the pictures yesterday.
Could have had a blow out on the free way.
Old Aug 29, 2011 | 11:51 PM
  #1798
My Key's Avatar
just putting a feeler out here, I'm gonna sell two of my flashes. Both are Canon 580EX I.
One is in really good condition and the other is in really used condition. lol
Old Aug 30, 2011 | 01:11 AM
  #1799
NFSP G35's Avatar
? = 2B || !2B
wow, Ash.... I didn't know you were sponsored by CarBodyKits...
https://g35driver.com/forums/exterio...place-get.html
Yeah... about that...
  #1800
NFSP G35's Avatar
? = 2B || !2B
Should have shaved really good first
