Pretty dead in here....
Old Feb 22, 2006 | 10:55 AM
_jb's Avatar
_jb
Photographer
Originally Posted by DrRabbitFurHead
Dude, you have an exhaust leak where the header flange mates with the engine block... 100% guaranteed...
So, like, couldn't he just tighten the header bolts...
Or, maybe put on a new gasket and tighten the header bolts...
Or, maybe put on two header gaskets and tighten the header bolts... double gaskets help the seal if there is an irregular surface on one of the flanges...
If it's hard to find the exhaust leak... put some talcum powder on your header flanges... it will blow off where the leak is... alternately, just crank down on each of the header bolts and see if any of them seem loose.
Old Feb 22, 2006 | 10:59 AM
_jb's Avatar
_jb
Photographer
Originally Posted by g8tor20
Where is everybody?
Originally Posted by _jb
Yes, it does seem a bit quieter in here.
I think people's interests change... some people are modded out... some sold their G35s... things in the FGC aren't as new as they were last year at this time.
And don't forget that damn board...
Old Feb 22, 2006 | 12:12 PM
r10apple's Avatar
Exactly, hard to find--especially by me!!! You really think the powder thing will work?
And gumba, see my dyno post a few down from this one on the whole issue at hand...
Old Feb 22, 2006 | 01:00 PM
WILD121's Avatar
its dead in here bc im not on as much..... im a little busy.
Old Feb 22, 2006 | 01:23 PM
SFLG35's Avatar
FGC President
i dont think that is a true statement there dan
Old Feb 22, 2006 | 01:26 PM
WILD121's Avatar
your a homo
Old Feb 22, 2006 | 01:33 PM
SFLG35's Avatar
FGC President
is that your only come back.
it seems to be since its the only thing you can say to me
Old Feb 22, 2006 | 01:37 PM
_jb's Avatar
_jb
Photographer
Originally Posted by WILD121
your a homo
It should be you're, not your...
Old Feb 22, 2006 | 01:40 PM
_jb's Avatar
_jb
Photographer
I think just tightening the bolts will work.
I've used powder to find other kinds of leaks... I don't see why it wouldn't work.
Old Feb 22, 2006 | 02:20 PM
r10apple's Avatar
But, if the stud was messed up somehow, I--I dunno that simply tightening is gonna work...
Old Feb 22, 2006 | 03:54 PM
_jb's Avatar
_jb
Photographer
I didn't realize that they were studs. In any event, you need to tighten the header to the exhaust manifold to eliminate the leak. If a stud is stripped, you'll probably need to replace it.
The above picture from the Service Manual notes that the nuts that hold the headers on are to be replaced after every use. I suspect that they are some sort of self-locking nuts.
I seem to remember that someone else installed your headers. I suggest you go back to them and explain your problem. If they do nothing and won't help you, mark them off your list, tell us, and we'll al avoid them in the future.
My long term solution for your problem is to call John Oliva at Lokey and explain your problem. I'm sure Lokey can fix your problem, whatever it turns out to be.
Old Feb 22, 2006 | 04:56 PM
r10apple's Avatar
that diagram helps me better understand which 1.5 stuf it likely is...Thanks, jb. I really do think my shop will take care of me, but if I have a problem, I will be in Clearwater March 6 so I will take it to Lokey...
Old Feb 22, 2006 | 05:16 PM
twinchell's Avatar
or whatever
Resurrect the post ***** thread!
Old Feb 22, 2006 | 08:30 PM
SFLG35's Avatar
FGC President
you should come two days earlier and come for our big meet
