Computer People!!!
Old May 10, 2006 | 10:39 AM
JEVERYDAY's Avatar
Originally Posted by Foo_G
is not meeting the EULA or HCL?
Is the windows XP cd a retail cd or an oem cd from dell?
This is normally the problem... Had that problem alot in my technician days.
Old May 10, 2006 | 03:34 PM
_jb's Avatar
_jb
Photographer
Originally Posted by audiblemayhem
well its not a dell cd and its not a store bought cd, but it has worked many times with my same exact laptop and also on my desktop.
That narrows down the choices...
XP is designed to be installed once and authenticated to that computer once. Microsoft has been increasing its efforts to strengthen its authentication program. They are very serious about it. They are much more serious about authentication that they are about fixing the bugs in Windows, unfortunately.
I did a quick Google search on the error you mentioned and most people reported the problem to be associated with dubious installation CD disks.
Old May 10, 2006 | 04:48 PM
dabomb's Avatar
FGC Central Florida BOD
true but this cant be checked during install. If he had the problem 128days after the install then I would say its an authentication problem.
I would first say its a bad CD. it can look good but if something that early is burned out on it then it will cause the whole installation to crash.
Second possibility is bad hardware, definately not limited to harddrive
Old May 10, 2006 | 05:17 PM
Foo_G's Avatar
Florida G35 Club, Premier Member
From: Universe.Milkyway.Solarsystem.Earth.NorthAmerica.USA.FL.Tampa
I have had laptops overheat during istall and cause the optical reader to flake out. Install is very resource intensive I was able to perfmon an isntall using VMWARE ESX virtual center and MS puts the tang to the ram and cpu.
I'd say if it feels hot put some spacers under each corner and run a fan over the laptop during the install to see if it helps. It cold simply be a case of thermal degeneration.
Old May 10, 2006 | 07:02 PM
Audible Mayhem's Avatar
well i got a start on it today, i sucessfully installed 98SE... lol
maybe it will allow me to upgrade. that is the plan so far
Old May 10, 2006 | 07:21 PM
ok so i thought 98 SE would work correctly. nope.
and XP wouldnt install over top of it. so i am back to square one.
Old May 10, 2006 | 07:31 PM
Foo_G's Avatar
Just dont fool with ME there are no upgrade paths from me. In order to upgrade from 98SE iirc you ned the xp upgrade cd not the full.
Old May 10, 2006 | 07:43 PM
_jb's Avatar
_jb
Photographer
I understand what you're saying. I doubt any of us could write code to "phone home" during a windows install... and why would it just start doing it now... after all these installs...
Old May 10, 2006 | 08:01 PM
i already tried that...
Old May 10, 2006 | 08:23 PM
lawrence's Avatar
try an external cd drive , or copy cd onto hard drive and install from that directory.
if has a hard time copping from cd, that is most likly the problem.
Old May 10, 2006 | 09:22 PM
thanks man i willl try that right now...
Old May 10, 2006 | 09:42 PM
cj350's Avatar
bring it to gainsville and i will have my friend look at it if its not done by then...... He builds computers
Old May 11, 2006 | 06:14 AM
thanks bro. hopefully i will have it done today when i get off work. we will see....
Rose M
Oct 12, 2015 10:00 AM
TurTLe*
Sep 29, 2015 01:43 PM
