What to do with ~10k Dollars
Originally Posted by rcdash
^ lame ^
you need to do a little research on some of the amazing G cars out on the road these days...
i love the G, not a talon, which is why I bought a G, nothing wrong with making it faster - 500 hp/tq not fast enough for you?
Nah, 500hp of tire spinning is quite fun, if thats what you like to do. I see that a lot of people put a LOT of money in their G35/350z's to make good hp. I guess it's to each his own. I like my cars to do what they do well.... G35 = luxy cruiser... I just think that unless you are VERY picky about who and how you build you "G", it ends up no longer being a daily driver....
Get yourself a playcar, put some rims on the G, lower it, audio, etc...
my .02
Originally Posted by mraturbo
Thanks Roneski for the good words.
How is your car running?
Calspeedway 7-21-06
www.Speedventures.net
M
Calspeedway 7-21-06
M
I'm literally going to be swamped wth work all summer long so I don't know if I'll make Cal Speedway. But I'll try if I can get that weekend free.
thx for the input on the vb - maybe waiting for the clutchpack upgrade is not such a bad idea...
In regards to the vibration:
i hit a rock doing 100 (passing going downhill!) about the size of a small watermelon! The G kept its composure when the rock hit the passenger front tire and went flying into the air but I developed an immediate vibration when turning the steering wheel slightly to the right (such as when changing lanes).
I had an ace suspension guy dx it for $20 before I went to the dealer. He told me the wheel bearing was damaged because there was too much play in the wheel (up on a lift - hold the tire and try to wiggle it). The dealer took 2 tries to figure it out and couldn't (did alignment, checked tires, checked suspension) and I finally had to insist that they replace the wheel bearing.
Presto - back to normal!
Cool, I'll check that out.
I got my left 2 wheels off course on a right turn that I was entering way too fast. Unfortunately there was a good 6 inch difference between the dirt and pavement at that particular spot. I slid on the left side of my frame for a good 30 feet. Hence the bent frame support and some heavy scarring on my frame rail.
Originally Posted by roneski
Car's running great. I went off course at LVMS pretty bad and I have a little vibration that I'm trying to get figured out. I suspect that a bent frame support could be causing it. Hopefully it's not bent so bad that a fresh alignment can't compensate for it.
M
Everyone saying 10k will get you a single turbo kit is wrong. It costs a tad bit more to have the thing running safely.
Everyone saying get APS TT is wrong also. 10-11k to install the kit, but where's the tranny accessories/gauges etc?
"about the size of a small watermelon!" lol that made me laugh..... :0) yea if im going to do FI ill go w/ the vortech.. but yea i dont know if i want to risk a blown motor :0/ we will see once this bike sells and i have 10k sitting infront of me.
Do not listen to james!!!!! you want guages and you want a tune when you fit your kit. most shops drop the motor to put the aps tt on, and parts plus labor will run you a little overyour limit. plan on 12,000 with exhaust, guages and tune. if 10 grand is your limit, i wouldnt look at the any of the tt kits.
James
I am getting the Greddy TT installed and tuned w/ everything: HKS F-Con IS (new smaller brother to V-pro) fuel pump BOV etc. for 8.7K. No gauges, I already have exhaust/test pipes.
Call Mark at SGP. I am basically getting parts for cost and he is charging 2.5 K for install and tune.
Originally Posted by BrianlG35C
For a decent build (after blowing your motor) with the best forged pistons and rods expect at least $10K+ including install.
