Im Pissed About My Car!
Old Jul 12, 2006 | 07:00 PM
  #31
MikeyMike's Avatar
Rollin On Dubz
This guy knows his ish kamal
Old Jul 12, 2006 | 07:07 PM
  #32
rookie's Avatar
He's a 5AT.
When you say it chokes at 4k, in any gear?
Old Jul 12, 2006 | 07:08 PM
  #33
roneski's Avatar
Devil's Advocate
How long have they had the car?
Old Jul 12, 2006 | 08:41 PM
  #34
Kamal34's Avatar
theyve had it for 8 months now... A lotta down time but hes hooking it up with labor cost which I WAS EXPECTING TO BEGIN WITH. I just want to remedy the situation now and not think of the $hitty past. It is an auto... Theyve pulled out the tranny and checked the flex plate but everything seems ok there.
Old Jul 12, 2006 | 08:43 PM
  #35
Kamal34's Avatar
ive had my tt kit on there for a while and no problems. This problem started when the car went back for the nitrous install. I drove the car around when I built my motor and no problems. I took it back and had Speed Force do my nirtous, alighn the tranny and do some powder coating in the engine bay. The sensors just gave up and we played around with replacing the old with the new.
Old Jul 13, 2006 | 01:40 AM
  #36
GurgenPB's Avatar
DId you say they shielded the cam wire. How did they connect the ground and power leads to the new shielded cam wire, assumign they ran a separate one (with three leads in it). REmember that these cars have differential grounds for each sensor, including the cam/crank sensors. If you just attach the ground to some regular ol' ground spot, it will behave exactly like you say. Why would you ever use the POS SS box anyway.... shops and their "preferred" EM choices. Noone does their homework. It's M-M, HKS, AEM, Utec/eManage Ultamate, Unichip, ...... , SS. I remember how Steve's car ran after Tim put on the SS box....5 degrees of timing advance. It's jsut plain unreliable (the SS), assuming the person installing them knows the box, which Tim does I believe.
Old Jul 13, 2006 | 01:44 AM
  #37
GurgenPB's Avatar
Another possibility, nitrous install requires the throttle position sensor tap in, correct (for the full throttle switch). Tapping into that kind of a line with a device that was poorly engineered (e.g. not high enough impedence), is asking for trouble. To find out the problem, you need to do evidence-based troubleshooting, and stop taking the car from place to place. Get Cipher, makesure you log all the channels, and just drive the car. When it hicks up, go back to the logs and see what's acting up.
BTW... don't forget to disconnect you nitrous solenoid and the throttle tap (or any other tap, like RPM).
Old Jul 13, 2006 | 01:47 AM
  #38
hai109's Avatar
Originally Posted by BlackOutG
you should lemon the car
Too modded...If they traced it back and it was something he did that affected it they will charge him 2 arms and 3 legs...(that's taking your sister's leg too) hahahha...but on a serious note he can't and they refuse to work on it. If i was the tech i would too. Those kind of problems turns out to be more work for a tech even if he charges 4 hours to try to find it...
Old Jul 13, 2006 | 01:53 AM
  #39
hai109's Avatar
Bro could be a bad ground when you went back to do the power coating or the nitrous set-up...Trace the wires back from the crank senor and make sure you didn't pinch any wires. Does it the code set right away?
Old Jul 13, 2006 | 02:00 AM
  #40
givemeanr1's Avatar
Damn Gurgen and G352NV no there stuff man!!! Best of luck on the car man it is definitley one sick a$$ G.
Old Jul 13, 2006 | 04:24 AM
  #41
G352NV's Avatar
Never enough
Well I think the responses in this thread have pretty much covered what needs to be said. Just go back to where you started having problems and go from there.
Side note, Gurgen knows his shiet!! This guy has been through more then anyone I know with these cars. I have a lot to learn still! But thanks!
Old Jul 13, 2006 | 05:11 AM
  #42
Kamal34's Avatar
omg you guys are freqan amazing. Im gonna have Tim chime in here tomorrow. Im gonna call him and he knows a lot more technicalities then I do. I do live 98 miles from Speed Force so im not 100% in the loop of things. Thank you soo much again guys and I really do owe you one. For everyone on this thread thats chipped in, I really do appreciate it. Hopefully when Tim comes on, he can answer a lot of questions and hopefully you guys can help me further. Thank you again everyone!
Old Jul 13, 2006 | 05:24 AM
  #43
Kamal34's Avatar
Nothing fancy but heres some pics of my car for those that havnt seen it so you can see how it looks like... Enjoy and hopefully you think its as sick as I think it is?
Old Jul 13, 2006 | 01:26 PM
  #44
zazaracing's Avatar
Team Transport Member
7 motors and Gurgen finally learned!!!! JK
Old Jul 13, 2006 | 01:34 PM
  #45
GZire's Avatar
Nice setup Kamal. I like the twin FMICs.
