Install S/C Pre-programmed piggyback without S/C?
Hi, Folks, I need some help here.
I am planning to install F-con S on my G35x AWD to see if it works
& let it run for a few weeks before installing S/C.
My F-con S is piggyback pre-programmed to HKS S/C (Rated 80HP only),
not turnable.
My installer think it'll run rich, may foul up the sparks, but pose no danger
to my car.
So my questions is,
1, Should I install the two external injectors with Fcon before adding S/C?
I am thinking without the two injectors, it'll be runing less rich, right?
How could I tell if the Piggyback is working?
2, Would install Plenum Spacer (which make my car run lean, as I already have a Stillen Cat back ) with the F-con S make it less rich?
3, Would 1 step colder plugs reduce fouling? or make it worse?
Thanks
not turnable.
to my car.
So my questions is,
Thanks
