supercharger and intercooler
Old Sep 14, 2006 | 01:39 PM
timpone's Avatar
why is there a need for a intercooler on a supercharger i alwaysthought the intercooler was for the exhaust air to cool down before goin to the turbo pls help cuz im reallyconfused bout this
Old Sep 14, 2006 | 02:07 PM
GT-Ron's Avatar
The very act of compressing the air heats it up. Most older supercharger applications didn't use intercoolers. I guess buyers have come to recognize the benefits enough that manufacturers offer/include them more often now.
Old Sep 14, 2006 | 03:08 PM
Brando's Avatar
Bingo.....the cooler the better.
Old Sep 14, 2006 | 03:43 PM
rcdash's Avatar
the intercooler does not cool exhaust gases, it cools the intake charge (same for superchargers and turbos).
difference is that turbos are driven by the exhaust gases (other side of the turbine to the intake pump) and not the crank like a sc...
Old Sep 14, 2006 | 05:28 PM
badtziscool's Avatar
Yeah. Very little heat transfer from turbos to intake air. It's just there to cool the compressed air. Old superchargers generally never had an intercooler so its myth is that they don't need intercoolers when in fact it would have been very beneficial.
Old Sep 14, 2006 | 06:42 PM
timpone's Avatar
oo ok thats what i thought about the superchargers that they didnt need one thnks for clearing that up for me
Old Sep 14, 2006 | 08:15 PM
rcdash's Avatar
You could similarly say that turbos don't need one. the point is that the process of compressing air, heats it. Heated air robs the engine of power besides having other bad side effects...
for all forced induction, intercoolers are helpful...
Old Oct 13, 2006 | 01:09 AM
rloyola0426's Avatar
does the vortech supercharger kit come with a front mount intercooler?
Old Oct 13, 2006 | 01:16 AM
meatbag's Avatar
It has a liquid to air intercooler that is mounted directly below it and a radiator that is mounted in the bumper to cool the intercooler fluid.
Old Oct 13, 2006 | 02:02 AM
so is it visible from the front like some turbo kits or is it hidden sleeper style
Old Oct 13, 2006 | 08:29 AM
superchargedg's Avatar
sorry you are wrong on that,the vortech has a air to air intercooler,the stillen has a liquid cooled intercooler.
Old Oct 13, 2006 | 09:03 PM
meatbag's Avatar
Yeah i was thinking about the stillen for some reason when i posted.
Old Oct 14, 2006 | 11:55 AM
Q45tech's Avatar
Important to understand the thermodynamic concept of compressing air.....that inefficiencies and friction of the impellers spinning in air and compressing creates the heat.
11F increase decreases total density by 1%. Balancing act between the PSI restriction of intercooler and piping vs the net cooler charge.
Losing 1.0 psi thru intercooler reduces density by 7%, dropping 77F compressed air thru intercooler gains 7%............proper intercoolers lose 0.5 psi so the net is 4%.
The major problem is gasoline has a knock index vs air temperature curve.
The intercooler can avoid excess ignition retard under boost so the GAINS from an intercooler are higher than from just the simple density improvement vs temperature. Instead of a net 4% as shown above you might get a net 6-10% depending on fuel used.
http://www.gnttype.org/techarea/turbo/turbocalcs.xls
http://www.me.umn.edu/education/courses/me5461/
For those that missed this engine design course in college: hand outs, lectures, reading and SAE papers thousands of pages in pdf if you follow links in above.
Old Sep 4, 2007 | 09:00 PM
ekko's Avatar
edit sorry wrong thread
Old Sep 5, 2007 | 01:36 AM
tylersphile's Avatar
Nicely explained Q45tech. Well done & thank-you.
seagrasser
May 3, 2022 09:43 AM
g.spot
May 9, 2016 10:54 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
9tray turbo
Sep 29, 2015 10:22 PM
