vortech 3.12 pulley
Old Oct 4, 2006 | 07:00 PM
TwilightBLUES's Avatar
vortech 3.12 pulley
hey guys wanted to know where is a good place to pick up the 3.12 pulley set up in socal. i have the stock set up right now with the vortech blower and only getting 5 psi at 6000 rpms. Is it a good idea to go with the 3.12 set up to get more boost? Would it be safe to do this without new injectors, or would i need that n more?
Old Oct 4, 2006 | 10:51 PM
SWATSON's Avatar
I picked one up at www.summitracing.com, they usually have things pretty cheap over there.
SWATSON's Avatar
I have the stock set up as well, but with plenum spacer, headers, HFC, and exhaust. I'm makin 8.7 lbs of boost. You sure your only at 5lbs?
Old Oct 5, 2006 | 12:14 AM
SWATSON's Avatar
^ I have the same 'breather mods'
Old Oct 5, 2006 | 02:16 AM
yea well i did have the car tuned after the "breather mods" , but i think i just found my problem today. my gasket for the kinetix plenum is gone bad. i would think this makes a big difference considering the compression lost.
swatson, by any chance is your spacer on the stock plenum?
Old Oct 5, 2006 | 02:19 AM
SWATSON's Avatar
yes motordyne 5/16" spacer on the stock plenum, why?
Old Oct 5, 2006 | 02:36 AM
caskyline's Avatar
Former Vendor
SWATSON you have the Fluidamper on your crank.It is larger in diameter.which will be overdrive,it is the same as putting a smaller pulley on the SC.That is why you got 8.7.On mine, I got 8.9 .
Old Oct 5, 2006 | 02:50 AM
Swatson, the reason i ask is i wanted to know if i went with a spacer, would it fit on the Kinetix plenum. i think it would.
and to add about the 3.12 pulley, how do you know which part it is on the summit racing website, i just see vortech products, but dont know which one to choose?
Old Oct 5, 2006 | 10:34 AM
SWATSON's Avatar
oh yeah... i forgot that i had that put on as well...
Old Oct 5, 2006 | 10:39 AM
SWATSON's Avatar
http://store.summitracing.com/partde...5&autoview=sku
Old Oct 5, 2006 | 08:54 PM
coo thanks a bunch Swatson, hopefully it shall be on the way soon. Btw what size belt did you run with that pulley? i have the gates 93.5 on right now
Old Oct 6, 2006 | 09:22 AM
kzanard's Avatar
For the 3.12 pulley you need a shorter belt (93.0")
Old Oct 6, 2006 | 10:45 AM
SWATSON's Avatar
I never installed the pulley, so I can't comment on what size belt. There are a few threads commenting on what people think is the best size belt.
seagrasser
May 3, 2022 09:43 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
NailBomb
Oct 28, 2015 07:53 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
