Dyno Vid
Old Feb 12, 2007 | 09:31 PM
HenryLee's Avatar
damn such a hot car..
Old Feb 12, 2007 | 10:26 PM
meatbag's Avatar
Originally Posted by JSpec350GT
Nice car and number Mark. I got confused about what you said by the way. HKS FCON VPro is a standalone engine management system but why would you need to do OEM ECU reflashing from Technosquare? I'm lost here.
T
Its a full standalone but keeps the OEM ECU for creature comforts and some other stuff like the DBW.
Old Feb 12, 2007 | 10:28 PM
meatbag's Avatar
Originally Posted by Mark350GT
8.5psi... with our cars each pound of boost equals to about 30 hp. Once i get some other stuff sorted out we are going to do a couple runs at around 10 psi with an aggressive setup. this will be the max the bottom end will hold. looking at 440whp
Have you thought about doing a dyno run with the stock plenum? 440whp at 10psi seems low for your setup.
Old Feb 12, 2007 | 10:48 PM
fastGkid's Avatar
that is the sickest G i have ever seen. def. my favorite G. i love it man great work. i wish i could get that paint job
Old Feb 13, 2007 | 12:03 AM
98intrigue's Avatar
So why did you dyno in 4th gear?
Old Feb 14, 2007 | 05:53 PM
Mark350GT's Avatar
yeah i need to. i am also losing torque with the kinetix manifold. on a couple of the low boost runs i did i wasn;t making the 380+ mark, its was more like 370. We think that the manifold has alot to do with it. Being a show car, i am going to leave the kinetix, but once its retired i am going to go back to the stock plenum with the plenum spacer.
440 was just a lowball number, A 350z here in dallas with about the same mods as me dynoed 453whp at 10psi. I am hoping to break at least 450 at the wheels. Only difference being that he is running the plenum spacer not the kinetix manifold.
4th gear dyno pulls are standard procedure for tuning because you get a longer curve to work with for tuning etc.. thats my guess.
Old Feb 14, 2007 | 05:57 PM
Mark350GT's Avatar
sorry i also forgot to mention that i got rid of the 440cc injectors and i am now running the 750cc injectors.
Old Feb 14, 2007 | 06:46 PM
Wicked_limitz's Avatar
sick!
Old Feb 15, 2007 | 12:37 AM
meatbag's Avatar
usualy you do 5th gear b/c its a 1:1 gear ratio. Anything else takes some correction and can lead to varying dyno numbers.
I can see using 4th to tune but for power numbers its a little fishy.
Old Feb 15, 2007 | 04:00 AM
98intrigue's Avatar
My thoughts exactly.
Old Feb 15, 2007 | 06:52 AM
Audible Mayhem's Avatar
when you are tuning, you want the longest gear possible when you are datalogging. it gives you the most accurate timing and fuel figures for each rpm.
the only reason people use 4th gear is because they dont know that 5th is 1:1 or they would like to put down a little higher numbers.
Old Feb 15, 2007 | 07:38 AM
2slo2bfurious's Avatar
SICK ride... I'm loving the color man. Hey all that work under the hood and no driverside battery cover!!!??
On a side note... What happens to people with a 3.3 FD with a manual? Does that change the 1:1 in 5th on the dyno??
Old Feb 18, 2007 | 08:46 PM
meatbag's Avatar
Gearbox is still 1:1.
Old Feb 27, 2007 | 08:30 PM
Mark350GT's Avatar
yeah i have some custom mirrored pieces being made for both sides instead of the ugly plastic.
Old Apr 30, 2007 | 11:54 AM
  #30
IvoryGT-V's Avatar
Nice dyno and hot car..Mark we have the same exact setup but I was only able to put down 396 whp only I dont have the kinetix I have a plenum spacer are you running any igniton.
seagrasser
May 3, 2022 09:43 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
reaper76
Sep 20, 2015 11:59 AM
