Gauge selection
Old Mar 27, 2007 | 07:43 AM
Glex25's Avatar
Administrator
Gauge selection
Hey guys need some input.
I was up late last night racking my brain on how to make this work and can't anyway to make it happen so I have to make a choice.
I need input on which gauges to put to the ride.
I have 4 gauges and can only fit 3 in a A pillar pod so one has to take a back seat.
Here are the selection:
Boost pressure
Oil Pressure
Fuel Pressure
EGT
I'm leaning towards leaving the fuel pressure gauge out for now unless someone can come with some creative ideas on how to make this work.
Does anyone make a custom pod for our sunglass compartment so i can fit 2 more gauges there. If someone does then I can also get a wideband O2 AFR gauge and just be done with everything.
Old Mar 27, 2007 | 08:31 AM
617G's Avatar
CFW (Carbon Fiber Whore)
are you FI? I think you're missing a Wideband AFR
Old Mar 27, 2007 | 09:02 AM
Glex25's Avatar
Administrator
Going FI within the next few weeks.
read the thread I want to install a Wideband O2 AFR but I rather have Oil/Boost/EGT if I had to make a choice of just 3.
Old Mar 27, 2007 | 09:37 AM
617G's Avatar
oops..hehe...sorry bout that...I think the 4 gauges that are a must are EGT, AFR, Boost, and Oil PRESSURE...i went with the tripple gauge pod and a Defi concept HUD which can display oil pressure, fuel pressure, oil temp, etc...OR you can get a Zeitronix wideband display and put it in your sunglass cubby to display afr, boost, egt, and use a tripple gauge pod for the oil and fuel sensors. Up to you. The other choice is to put two gauges in the upper cubby if you don't have a nav.
Also, if you're going FI, an AFR is a MUST...don't even think about running FI without it...IMO, oil pressure, although helpful, is a luxury...whereas AFR is a basic necessity. Don't skimp out on the AFR for oil pressure.
Old Mar 27, 2007 | 09:41 AM
Glex25's Avatar
Administrator
The cubby is already housing my Avic Nav system.
I don't use sunglasses so I wanted to see if anyone made a custom 2 pod system since i seen those on other cars.
Old Mar 27, 2007 | 09:43 AM
617G's Avatar
you're not gonna fit a gauge up there...not without some serious custom work...there is nothing readily available. Google Zeitronix. You can fit that in the sunglass cubby...I did when I had the vortech.
Old Mar 27, 2007 | 12:16 PM
98intrigue's Avatar
You could always put a guage in the air conditioner grille or down in the ash tray.
Old Mar 27, 2007 | 03:21 PM
imalazeeass's Avatar
i put my 4th gauge in the middle of my speedometer. As for the 5th wideband gauge, you're gonna need custom work
Old Mar 31, 2007 | 02:23 AM
Triple8Sol's Avatar
Based on what you want, I also suggest you get the Zeitronix. With add-ons, it can measure several different things you want, in one unit. I didn't get it just because it would be hard to read on the fly.
Old Mar 31, 2007 | 02:46 AM
Mr_pharmD's Avatar
I would do wideband, fuel, and boost. I did wide, boost and oil pressure and I feel the oil pressure is a waste. I would rather have fuel pressure so I know if my injectors are maxed or not working.
Old Mar 31, 2007 | 02:54 AM
Meatshackle's Avatar
Deep Sea Moderator
Wideband would be #1, then boost, then oil or fuel pressure.
Old Mar 31, 2007 | 05:51 AM
Triple8Sol's Avatar
I agree with that. For the 3rd gauge on the A-pillar pod, I ended up choosing oil pressure. It's nice to have, but sometimes I wish I had fuel pressure also (or instead). At least I know I could use the same gauge for fuel pressure, just have to adjust the wiring, etc...
Old Mar 31, 2007 | 02:12 PM
98intrigue's Avatar
I'm just running a wideband and a boost gauge in the nav cubby.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
alessandro
Oct 8, 2015 09:29 AM
9tray turbo
Sep 29, 2015 10:22 PM
JustinMKN1
Sep 18, 2015 03:40 PM
