Let's talk superchargers
Old Apr 10, 2007 | 11:29 AM
booger's Avatar
Originally Posted by Triple8Sol
I've been wondering why I haven't seen any Z's or G's running a diverter valve. Is the ATI's recirculation valve the same thing then?
They basicly do the same thing except the ATI valve recirc's it back to the blower and the Vortech bypass valve vents it
They both are open under vacuum and close under boost
Old Apr 10, 2007 | 11:52 AM
Ivory056MT's Avatar
Originally Posted by booger
OK...but you are still a little off . The fuel preasure doesnt rise with vacuum . It rises with boost
I don't know, page 10 of the install manual says hook the line to a vacuum signal....
Boost and vacuum rise and fall together, the FMU measues vacuum. It implies the boost level from the manifold (sp?) vacuum signal and increasses fuel pressure.
JH
Old Apr 10, 2007 | 12:02 PM
booger's Avatar
JH
The vacuum hose goes from the FMU to the plenum . The plenum see's both vacuum and boost . Under normal driving conditions the plenum will see vacuum , and the FMU see's that vacuum and keep the fuel preasure at normal psi levels . Once boost starts to rise the FMU will increase the fuel preasure at a rate of [ 8 to 1 ] or [ 6 to 1 ] depending on the year your Vortech SC kit is . Earlier year kits had a 8 to 1 and 2004.5 and newer kits had a 6 to1 FMU . Hope that explains it clear enough .
Old Apr 10, 2007 | 02:06 PM
Ivory056MT's Avatar
Not really, but I looked it up somewhere else and found out you are right. You learn something new every day.
JH
Old Apr 10, 2007 | 02:41 PM
Jeff92se's Avatar
Red Card Crew
BOVs vent to atmosphere. People like it because of the "shoosh" sound.
Recirculation valves "vent" back into the intake system.
The problem with BOVs, is they tend to vent air that's already measured (if it's mounted after the MAF sensor). When you vent measured air, it sometimes creates rough running and sometimes stalling. As the ecu sees contradictary information. ie.. air that supposed to be there but isn't.
Old Apr 10, 2007 | 03:07 PM
booger's Avatar
vortechs vent before the IC and the MAF
Old Apr 10, 2007 | 08:16 PM
trey.hutcheson's Avatar
Thanks for the discussion guys. This is exactly the type of info I was looking for.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
AJC128
Nov 1, 2015 11:55 AM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
9tray turbo
Sep 29, 2015 10:22 PM
corynooooo
Sep 26, 2015 10:54 AM
