GT Motorsports Turbo and NA/SC Spec Camshaft Dyno Testing Results
Old May 3, 2007 | 03:44 AM
SAM@GTM's Avatar
Exclamation GT Motorsports Turbo and NA/SC Spec Camshaft Dyno Testing Results
We are very pleased to annouce the results for our GTM Spec N/A and Turbo cams. These cams were introduced back in november (See thread here: http://www.my350z.com/forum/showthre...gt+motorsports) since then we have sold/installed appox. 30 sets. Some of these cams went to distributors, some to customers, and some to projects that we have been working on in house. We felt that the only way to REALLY know that gains is to have the cams installed on selected cars that were ONLY getting the cams installed and nothing else, Then dyno the vehicles before and after. so we can really see the effect of the cams, and also seek the customers opinions after they receive their car since they knew the car before more than anybody else. Now defiently having a dyno graph is proof but also confirming what we are seeing on the dyno with the driver input is a home run.
Test Car #1 - Twin Turbocharged Engine
Vehicle background before GTM camshaft installation:
(jeff 350z) vehicle is equipped with APS Twin Turbo, APS exhaust, Stage 1 GTM shortblock, Stage 1 GTM heads, Nismo R-Tune cams, F Con V Pro running 14 psi. All work and tuning was done by GTM.
Dyno graph below shows dyno #34 with the above specs:
BEFORE:
Car came in to upgrade/install APS exteme fuel system and GTM camshafts with a retune for the new fuel system, No other mods were done to the car
AFTER:
Before and After overlay:
Dyno Conclusion:
Our GTM Spec cams are designed for great midrange and noticable improvement across the board, and have done a very good job at accomplishing that as shown above. Hopefully Jeff will be chiming in soon to give us his input.
Test Car #2 - Supercharged Engine
Vehicle Background:
Before camshaft installation (eric 350z mt ) vehicle is equpped with a complete Vortec kit, nismo exhaust, Plenum spacer and stock cats engine is stock (stock compression)
BEFORE:
This dyno#4 done 2/9/05 represents base line only NO tuning was preformed by GTM, Eric brought his car to us to strickly do a baseline dyno to see what his car was doing at the time. VORTEC STOCK BOOST
AFTER 1:
This dyno below was done with the GTM Stage 1 block, 8.5:1 compression GTM stage 0 heads, and GTM N/A cams with NO tuning preformed VORTEC STOCK BOOST. Eric came back for these upgrades because he had an engine failure, besides the upgrades listed up above the car still has the same exhaust, the same spacer, the same fuel system, same split second, same tune, and same pulley. With this dynograph below we still have NOT touched the car as far a tuning goes(same tune as dyno sheet above)
AFTER 2:
After the engine was broken in, this dyno was done with the 2.87 pulley, upgraded injectors, @11 PSI of boost, factory cats, walbro 255, fuel return system, with GTM tuning the split second box
Below is a Dyno graph overlay of this car with the 3 graphs, Blue is the car with no tune out of the box Vortec kit installed. Red is the car with the camshafts with out tuning, and the green is the car with everything tuned and ready to go!
Overlay:
Conclusion:
This vehicle showed signifact improvement, to be honest we did not even expect this much improvement with just cams. A few points I would like to make clear, granted the vehicle had a set of fresh heads with a valve job the lower compression on the engine should have really reduced power instead of gaining so much, which really shows these cams are working very well.
Test Car #3 - Naturally Aspirated Engine
Vehicle background before camshaft installation (Mark G35 Coupe A/T) vehicle is equipped with GReddy SP2 exhaust, OEM cats, Motordyne 1/2 Plenum Spacer, AEM Cold air intake, Unorthodox Pulleys, no tuning was done on the dyno shown below.
BEFORE:
AFTER 1:
Installed GTM Spec N/A Cams, HKS Hi-Power exhaust, still stock cats and NO tuning:
After 2:
Installed GTM Spec N/A Cams, HKS Hi-Power exhaust, still stock cats, and install and tune HKS F-Con IS:
Conclusion:
Car felt great on test drive, Mark was very happy and felt a differeance instantly hopefully he can chime in and share his thoughts.
Old May 3, 2007 | 04:09 AM
martyg35's Avatar
awesome gains ..more stuff to add on my wishlist
Old May 3, 2007 | 04:39 AM
AboostedG's Avatar
The first two test cars you're showing are very impressive indeed, while the third after all that was done, not so much.
Old May 3, 2007 | 12:13 PM
sentry65's Avatar
that turbo car was making around 500whp to start with
so of course adding cams to it will have a larger gain with it than the other cars which are less powerful
the higher amount of flow would mean that the boost pressure would drop slightly.
The wastegate is trying to maintain what it's set at so it will let more air go into the engine instead of out the wastegate. This is common sense with a turbo setup, that some of the gains you're seeing aren't from the cams themselves, but also partly from the turbo's additional air
these cams are winners IMO
Old May 3, 2007 | 12:26 PM
Ralph0064's Avatar
very, very nice write up. Thanks for sharing.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
Team STILLEN
Aug 10, 2015 08:17 PM
