Ok to use 440 injectors w/ basic Vortech kit?
Old May 8, 2007 | 11:17 PM
waijai's Avatar
i.love.gold
Buddy of mine upgraded to 750 injectors and has the 440's laying around. Can I use them with my basic Vortech kit? I don't plan on changing out the pulley, but if they're available might as well throw them in there right?
Old May 9, 2007 | 09:30 AM
617G's Avatar
CFW (Carbon Fiber Whore)
Unless YOU or a shop near you knows how to scale injectors properly, I wouldn't do it. The SS box cannot scale injectors so it's up to the ECU to do it and you need someone very experienced to be able to do it correctly. Otherwise, your fuel trim might get pegged and you'll be blowing dried carbon chunks out your tailpipe.
Old May 9, 2007 | 12:10 PM
FastDontLie's Avatar
...we dont need roads...
Are you going to be using the SS box and the Vortech FMU?
Old May 9, 2007 | 12:20 PM
b00stedjustin's Avatar
another reason why turbo kits are superior. 750cc injectors are huge!!! how much hp is your friend making?
Old May 9, 2007 | 12:28 PM
617G's Avatar
is that directed towards me? I never made a comment about a "friend" lol
This actually happened to me when I had the Vortech, but it was under different circumstances. My cog pulley was messed up so we took out the blower and ran a filter on the end of the pipe. Well, I left my lights on once and killed my batt overnight and when I jumped my car the next day my fuel trim was all messed up and I was blowing white smoke out of my pipes as well as dried chunks of carbon after driving all day. It was technically my fault because I got on it a little too much and with no boost there, the ECU didn't know what to do with all of the fuel.
Old May 9, 2007 | 07:20 PM
waijai's Avatar
i.love.gold
right now SS box and Vortech FMU
Old May 9, 2007 | 09:03 PM
I think you need to upgrade your FMU when running bigger injectors. If im right then its just the FMU disc and runs about ~$30.
Old May 9, 2007 | 09:38 PM
ttrank's Avatar
Grocery getter
^^^+1
I would get them incase you decide to go bigger later.
Old May 9, 2007 | 09:39 PM
ttrank's Avatar
Grocery getter
Tony over at UMS Tuning has 1,600cc injectors on his EVO.
Old May 10, 2007 | 12:05 AM
Flipjnh's Avatar
I agree about a better FMU, But you might as well get a new ecu while your at it because once you start changing your internals your going to need it.
Old May 10, 2007 | 01:04 AM
ttrank's Avatar
Grocery getter
Wow your location is crazy!
Old May 10, 2007 | 06:41 AM
Flipjnh's Avatar
yes it is
Old May 11, 2007 | 05:30 PM
booger's Avatar
Moog
I would hold on to the 440's for later . WHy fix something that isnt broken ? Later if you start having problems with the fuel system [ FMU , pump , or injectors ] you have the 440's on hand to install .
If plans are to keep the stock pulley on...no need for them and no extra money spent making the 440's work .
Old May 11, 2007 | 07:00 PM
waijai's Avatar
i.love.gold
Yeah I'm thinking just hold on to them for when I actually have money to upgrade it right. I'll probably eventually go with a different pulley and upgraded fuel system & engine management.
seagrasser
May 3, 2022 09:43 AM
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
g.spot
May 9, 2016 10:54 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
