What size injectors?????
Old Aug 22, 2007 | 04:14 PM
JDM7672's Avatar
what size injectors are u guys running on your turbo application on stock internals??
Old Aug 22, 2007 | 04:39 PM
Hi-TechG35's Avatar
Usually people aer running 440cc or if you have a sick mechanic he can run secondary injectors for you (Ballastic Motorsports)
Old Aug 22, 2007 | 04:46 PM
sliderg35's Avatar
+1 440cc.
Old Aug 22, 2007 | 06:46 PM
nyqueenz's Avatar
only go bigger injectors for bigger applications.. bigger tubros..
Old Aug 22, 2007 | 07:45 PM
XKR's Avatar
XKR
I am using 1000cc HKS injectors
Its not stock internals though
Old Aug 22, 2007 | 10:58 PM
nyqueenz's Avatar
sumdang like i have on my GT4092R setup..
Old Aug 23, 2007 | 08:16 AM
Audible Mayhem's Avatar
stock motor you can run 650cc injectors with no fuel return system all day long.
if you want to buy a return fuel system then you can use 440s.
pm me if you have any questions...
Old Aug 23, 2007 | 03:37 PM
ttrank's Avatar
Grocery getter
I have been running 8-9psi on my Greddy kit with 440's since December. I got a fuel return kit a couple months ago but that is for the future, the car was fine before.
Old Aug 23, 2007 | 03:46 PM
ISMSOLUTIONS's Avatar
550's will also work well. You should really do the sizing math though to be better on target with your HP goals. I would suggest going 1 step higher that what is ACTUALLY recommended for your goal though - just to be sure you have enough under a range of circumstances.
Remember the stock injectors are like 280CC's and handle a good 350-~385 HP. At the minimum - 380CC's, like some of the turbo kits provide by default..440's are a GREAT first step though.
Keep in mind - as a general rule - the CC rating is real close to what your goal HP will be. So 440's would get you to about 440 HP - 550's to that range, etc. Once you build the motor, do cams or heads, etc...that theory goes out the window.
Rick
Old Aug 23, 2007 | 03:55 PM
Hexxum001's Avatar
I'm running 550cc DW injectors.
Old Aug 23, 2007 | 04:12 PM
FI'ed G's Avatar
I have 440 and based on my Utec logs at around 7psi my injector is already hitting 90 at high RPM.
PHP Code:
                                Mod
RPM        MAP        TPS        Inj#1        Ign
        psia        %        duty        deg
5184        7        97        77.5        12.8
5184        6.9        97        78.5        13
5241        6.9        98        78.6        13.1
5249        6.9        98        79.5        13.2
5333        6.7        98        79.6        13.3
5333        6.9        97        81.3        13.2
5393        6.7        97        82.1        13.3
5402        6.8        98        82.3        13.2
5428        6.7        98        82.5        13.4
5473        7        97        83.9        13.4
5428        6.6        97        84.3        13.5
5527        6.7        98        85.2        13.5
5555        6.8        98        85.1        13.6
5583        6.7        97        84.9        13.8
5630        6.7        97        86        13.9
5611        6.7        98        86.4        13.9
5668        6.8        98        86.5        14.1
5707        7        97        86.9        14.3
5737        6.8        98        88.1        14.4
5767        6.7        97        87.5        14.7
5807        6.8        97        87.8        14.6
5827        7        97        88.1        14.6
5847        6.7        97        89.2        14.7
5899        6.8        97        88.5        14.9
5910        6.8        97        89.4        14.7
5920        6.6        97        89.6        14.8
5984        6.7        97        89.6        15
5973        7        97        89.2        15.2
5995        7        97        90.6        15.2
6027        7.1        97        90.5        15.2
6127        7.1        84        89.6        15.3
6093        5.9        1        69.1        19.4
Old Aug 23, 2007 | 05:55 PM
Hexxum001's Avatar
Time for some 550's bro!
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
johnadlertech
Interior
Sep 4, 2015 12:26 PM
