Oil Specs for FI
Oil Specs for FI
I'm running a Greddy TT now. What Oil specification (eg: 5w-30) is best for this type of application. (Let's not get into which manufacturer is best - I thinks that's been flogged to death by now.)
IMHO. The oil's characteristics is much more important than the weight. So unfortunately, you will have to discuss each maker's offerings.
But for FI, it HAS to be 100% synthetic. Question is which one. I'd go Amsoil and have it analyzed every 5k for wear.
Originally Posted by AthenG
Search the Oil Thread sticky on my my350z but I'm using Mobile 0-40, if this is good enough for GTM then it is good enough for me...
Originally Posted by Matt at PF
try red line 10w40
I was running Motul 300V 5W40. I had it analyzed and I am not impressed. I had higher level than normal form Aluminum, Iron, and lead. That is pretty much telling me that I am having wear on the pistons, cylinder walls, and bearings.
Motul 300V 5W30 yielded similar results on someone elses FI VQ, too.
Right now, I am running Rotella T Synthetic 5W40. I'll see how that goes.
