SSQV on Supercharger help
Old Sep 22, 2007 | 08:16 PM
SilviaVsSupra's Avatar
the question i have is; why do i not hear it? when i make like 4psi all i hear is a minimal woosh and i never hear the famous squeal of that little booger, i adjusted it but didnt make any difference, and yes its blowing to atmosphere. anyone know? maybe i need a beter vacuum line?
Old Sep 22, 2007 | 09:44 PM
Jtrain's Avatar
Originally Posted by SilviaVsSupra
the question i ? 4psi ?
Old Sep 22, 2007 | 10:29 PM
uhm.. what?
Old Sep 24, 2007 | 01:46 PM
waijai's Avatar
i.love.gold
Only running 4psi, it's not really going to be that loud I would assume.
Old Sep 24, 2007 | 02:17 PM
Jtrain's Avatar
I run 4.5-5psi and Get a really nice BOV, /shrug depends on how long it spools tho
Old Sep 24, 2007 | 03:11 PM
possibly just the difference in flow from a supercharger and turbo? even at full boost (7ish) i only get the flutter sound of like a factory bypass valve.. its upsetting..
Old Sep 24, 2007 | 03:30 PM
waijai's Avatar
i.love.gold
might be adjusted too tight. My vortech bypass valve is pretty loud
Old Sep 24, 2007 | 08:52 PM
aero's Avatar
I'm guessing a shop installed it, since it's a custom weld job? I have one with my SC, but I'm running 9 psi, so that little beast hisses. Do you know if you have the correct flange? I think it's 60 mm.
http://www.alteredatmosphere.com/mm5...y_Code=350Z_FI
Old Sep 24, 2007 | 11:05 PM
it is a welded on flange, and its hard to weld on the wrong flange and still work lol, one thing i was thinking is that the air hose is super long, like 4ft long! could that be the problem? and i did losen it alot without making any change.. could it be stuck? maybe im just hearing the reverb instead of a bov... i need to find a buddy's and swap them
does the newest ssqv have the same flange?
Old Sep 25, 2007 | 09:29 AM
aero's Avatar
Hahaha, hey you never know, after seeing some of the horror stories on here! As far as I know the newest SSQV uses the same flange (at least it did 3 months ago). Don't know about the hose though, a shop did my install too, I have the welding skills of a 3 year old.
seagrasser
May 3, 2022 09:43 AM
Mad A
DFW Classifieds
Mar 28, 2016 11:25 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
9tray turbo
Sep 29, 2015 10:22 PM
