Vortech tune?
Old Oct 18, 2007 | 05:48 PM
Brando's Avatar
Cool
When I installed the 3.12 pulley, I had Sharif retune it....very conservatively.
I normally hit between 10.1 - 10.5 max.
A litle rich is a little safer.
My tail pipes are really black.
Old Oct 18, 2007 | 06:08 PM
waijai's Avatar
i.love.gold
Cool, you've been a great help so far. I was a bit low on oil when I checked earlier this week(good thing I have an ARC oil pan which takes an additional 1-1.5 quarts). My car is high mileage...close to 85k miles.
Is there any way to visibly inspect the blower for a bad seal? Or do I have to disassemble it?
Yeah my Ings rear skirt has my Fuji tips slightly tucked in, so the whole rear bumper gets REALLY dirty b/c of tip placement.
Old Oct 18, 2007 | 06:30 PM
Dan_K's Avatar
Check pipes and intercooler for oil. Also look underneath the blower to see any oil stains. If not, you're good to go.
Old Oct 18, 2007 | 06:37 PM
ISMSOLUTIONS's Avatar
+1
If you pull an intake tube - and see any oil, you'll know.
also - an easier check would be the bypass valve. If you have a filter on it, check it and see if it has oil all over it or the areas behind it and around it are oily/filmed. If so, then there is oil in your intake and then oil coming past the blower seal.
Rick
seagrasser
May 3, 2022 09:43 AM
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
AJC128
Nov 1, 2015 11:55 AM
Usman Ali
Oct 4, 2015 08:23 PM
