Loose Belts Vortech
Old Nov 9, 2007 | 04:27 PM
falcon50driver's Avatar
Loose Belts Vortech
I was always concerned that I wasn't achieving anywhere close to 8psi boost on my Vortech setup. Somewhere around 4.5 - 5.0 at 6500 rpm. I checked all connections and still 1/2 the advertised boost. The belts seemed tensioned correctly and then last week I heard the belt squeal, especially right at start up.I re-tensioned the adjuster and took it out for a drive to find that now I was getting somewhere around 6.5 psi of boost. After 1 hour of normal driving the squealing came back and boost dropped. I checked the tension, and no change in tension. How far can the belts be tightened? They are pretty tight now, around 1/2" deflection on longest belt run.
Old Nov 9, 2007 | 04:43 PM
Dan_K's Avatar
You might have a leak somewhere on the plenum. Make sure that your filter is clean. Triji had a dirty filter and he was loosing about 2-3 psi of boost. After cleaning it, he got back to 8-9 psi.
Old Nov 9, 2007 | 04:59 PM
Hexxum001's Avatar
^^^Like he said, check for leaks and the filter first. How long have you had that belt? Sometimes belts stretch and tensioning it to the max won't help. Might be time for a new belt.
Old Nov 9, 2007 | 05:37 PM
G35Asian's Avatar
Yeah, it seems as though you have a belt that is too long to begin with or is stretched out. Get a new smaller belt so you have more room for tensioner to adjust and make sure the belt is TIGHT (toight like a toiger, LOL).
Old Nov 9, 2007 | 06:20 PM
Hexxum001's Avatar
Don't you mean tight like a virgin?
Old Nov 9, 2007 | 06:26 PM
Thanks for the tips, however, The unit was installed in may of this year, and has less than 1200 miles on it, so I don't think wear or dirty air filter is the culprit. I'll check the plenum. I myself put new extended length sleeves on all connections just to eliminate the possibility of leaks. I really do think the belt is the issue. I'll try to tighten a bit more, but just don't want to overtighten...
Old Nov 9, 2007 | 07:45 PM
Dan_K's Avatar
Is the tensioner close to maxing out? If so, time for a new belt. Just take a look at the filter anyway, you never know. A good test would be to run your car around the block with no filter and see if you make full boost.
Old Nov 9, 2007 | 10:09 PM
booger's Avatar
That GoodYear belt seems to stretch very easy . Get a Gates belt on it and tighten it up real tight . Then get back to us on it .
Old Nov 9, 2007 | 10:53 PM
HEGONE's Avatar
A BIG +1!! The gatorback belt that comes with the kit is garbage. Go for the slightly smaller gates belt and tighten it good. Its what I did, and boosting is amazing now!!
Old Nov 10, 2007 | 12:27 AM
Sundeviljay's Avatar
i'm getting the pulley mod added tomorrow along with a new belt, clean filter, and even some sparco seats! i'll let you know how everything turns out as I have been having a belt squeal and low boost for a few months now i've been too lazy to fix it!
Old Nov 10, 2007 | 12:42 AM
Mr_pharmD's Avatar
Do the Timrod method bc that thing works like a champ. I'm at 15psi and no SLIPPING at 6500 rpm.
Old Nov 10, 2007 | 01:35 AM
Triji's Avatar
Do this GTM pulley mod and say buh bye to belt slip....
Old Nov 10, 2007 | 06:57 AM
Dan_K's Avatar
GTM mod looks like it would work better than the timrod mod, but both are good.
Triji - What kind of strut bar is that and where did you get it? Will it clear the APS plenum?
Old Nov 10, 2007 | 09:29 AM
Thanks for all thr input. Question...what exactly are the GTM and Timrod mods??
Old Nov 10, 2007 | 09:31 AM
Sportcoupe35's Avatar
My Vortech is having the same problem. At first start up I'm getting a loud squeeling noise and especially now that its getting cold, its getting loud.
