GReddy turbo install, now no start
Old Dec 30, 2007 | 10:20 PM
ttrank's Avatar
Grocery getter
Good luck. Please let us know what the problem turns out to be.
Old Jan 2, 2008 | 05:31 PM
EnduroMTS's Avatar
Yeah, but if anyone stumbles across this in the meantime with the answer, feel free to share
Old Jan 3, 2008 | 02:01 PM
EnduroMTS's Avatar
So i got the tranny out and checked the flywheel dowel pins, and it was off by 1 hole. So whether thats the culprit of the no start is still yet to be seen but we'll know for sure once we put everything back together.
Old Jan 3, 2008 | 06:33 PM
Sinister350GT's Avatar
I fawcking Knew it. WHat brand fly wheel was it?
Old Jan 9, 2008 | 03:21 PM
ttrank's Avatar
Grocery getter
Any updates yet?
Old Jan 9, 2008 | 04:28 PM
GreenGoblin's Avatar
The goblin resurrection
Hope that solves your problem
Old Jan 15, 2008 | 07:22 PM
EnduroMTS's Avatar
So today after putting everything back together, we got the car on the ground and the battery charged. Went to fire it up and it starts up perfect. Only problem is after starting it up it, it wants to die and as the rpm's shot back down it dies. Any ideas? I've checked the grounds, spark, fuel, management and ecu... Im assuming it has to do with the Vacuum lines?
The exhaust isn't back on, but that shouldn't cause it to die, if anything just rumble like a open header on a car.
Sinister350GT Its a stock flywheel.
Help!
Old Jan 15, 2008 | 07:59 PM
AGThing1227's Avatar
Well its good that you got it started. Thats the main thing. I do not know what the next problem could be but I wish you luck. But check the little easy things for the mistakes. That is useually the problem.
-AGThing1227
Old Jan 15, 2008 | 08:00 PM
EnduroMTS's Avatar
-AGThing1227
Thanks Yeah I just got checking the basis, Been messing around with the Vacuum lines that go from the head to the waste gates, but it's getting confusing!
Old Jan 15, 2008 | 08:59 PM
panda007's Avatar
Has the plenum been removed and reinstalled? Check the sealing on the plenum (my problem due to stumbling).
Old Jan 16, 2008 | 12:11 AM
i had issues with the car sustaining idle. we had the MAF housing upside down!! make sure the arrow is pointing to the intake
Old Jan 16, 2008 | 12:26 PM
EnduroMTS's Avatar
I didnt even think about that! I'll give it a shot.
panda007 Checked the plenum. Its sealed
Old Jan 16, 2008 | 03:24 PM
EnduroMTS's Avatar
So I checked out the MAF Sensor. Its on there the rite way. Any one have any more idea's
Could it be due to vacuum lines to and from the waste gates?
Old Jan 17, 2008 | 02:49 PM
EnduroMTS's Avatar
Bump for the day!
Anyone have a wire diagram on the ECU?
Old Jan 18, 2008 | 01:12 AM
  #30
I do but its 13 megs
or 4.5 megs zipped
