boost controller..can i use one?
Old Jan 16, 2008 | 02:06 PM
IrockAG35's Avatar
Ohio G Club moderator
Question boost controller..can i use one?
recently had an ati procharger kit installed...running around 7 psi on stock everything...can i use a boost controller to up my boost?..and do i need any other mods?
Old Jan 16, 2008 | 02:19 PM
TURBOTOM's Avatar
a.k.a kleicoupe
Post this in the Forced Induction sectoin, or have the mods move it.
Old Jan 16, 2008 | 02:41 PM
617G's Avatar
CFW (Carbon Fiber Whore)
no
Old Jan 16, 2008 | 03:27 PM
doctorG's Avatar
hahah. Yes if you want to blow ur motor.
Old Jan 16, 2008 | 03:46 PM
ttrank's Avatar
Grocery getter
Can a mod for this section please move this to the FI section.
Answer:
No because you have a supercharger which requires a pulley and engine rpm to determine your boost.
A boost controller controls the wastegate(s) on a turbo setup because turbos will just keep making more and more boost until the wastegate(s) open or they reach their max boost.
Old Jan 16, 2008 | 06:53 PM
Xblackg35X's Avatar
yeah your gonna have to get the 9 lb pulley. did you add a filter onto the end of your procharger? i forget who it was but they said they got more boost out of it. i dont see how but im gonna try it when i retune my car.
Old Jan 16, 2008 | 06:54 PM
Xblackg35X's Avatar
by the way how much hp and tq did you get with mods? you can pm me if you want
Old Jan 16, 2008 | 08:38 PM
istan's Avatar
Originally Posted by ttrank
Answer:
Yes if you add a wastegate to your SC setup and overboost on purpose. Still trying to look for more results from this.
Old Jan 17, 2008 | 09:58 AM
ttrank's Avatar
Grocery getter
What?
Are you going to run a wastegate on the intake pipe or something kinky like that? A wastegate routes exhaust gas away from the turbo and straight into the exhaust. That won't help a sc at all...
Old Jan 17, 2008 | 11:00 AM
FI'ed G's Avatar
What?
I think it has been done but they where running the T-trim blower. wastegate help them give that extra boost on the lower-mid RPM that the T-trim gives and at the same time vent the extra air after a certain PSI that you want has been met... kinda weird but I can't verify right now if it actually work 100%.
Old Jan 17, 2008 | 11:23 AM
istan's Avatar
What?
I remember reading about a G with a Vortech. Basically, set up a waste gate to route the intake air out of the stream, that way they are able to overboost, and control the amount boost entering the motor. Same function (remove air), different location.
Old Jan 17, 2008 | 01:12 PM
waijai's Avatar
i.love.gold
yeah if I remember correctly, running say a 12 psi pulley, but only allowing it to hit 10psi at peak. This would increase the "under the curve" power, yet still allow a safe peak HP.
Old Jan 17, 2008 | 01:20 PM
istan's Avatar
Also, with the wastegate and Boost controller in place, you would (theoretically) be able to use different maps for different psi.
More or less, boosting a 12PSI pulley will give you more gains in the lower RPMs, but can still limit the boost reached in the higher RPMs to keep things safe.
Old Jan 17, 2008 | 01:45 PM
IrockAG35's Avatar
so its can be done...sounds a little confusing..dont know alot about turbos quite yet...this is first one ive owned..thanks for your input..im putting down around 340@wheels...stock exhaust/headers/injectors/manifold...if i chang these things..you guys seem to know...what kind of results do you think i would get?
Old Jan 17, 2008 | 02:10 PM
istan's Avatar
Can it be done, yes. But it'll take a lot of time, money, planning, etc.
I'm not exactly sure of the power the procharger produces.
