Boost gauge/controller install help
Old Feb 29, 2008 | 02:34 PM
CHudson Coupe's Avatar
I will be installilng a boost gauge and greddy profec b spec II controller in my dash and want to know the best way to route the vacuum hoses. Is it ok to just run one long one into the engine bay and then have a "T" at the end of it behind my center console and then have 2 short lines go from that to the controller and gauge? Or should I have separate lines running from each directly into the engine bay.
Old Feb 29, 2008 | 03:52 PM
ttrank's Avatar
Grocery getter
You can put a T on it. Depending on your boost gauge you could also have a sensor that stays in the engine bay so you only run 1 in anyway. That's how mine is.
Old Feb 29, 2008 | 05:42 PM
Thanks, I know its all just vacum lines anyways, but wasn't sure if I would have too many "T"s. I just want to put my radio back in but need all of the wiring and hoses ready so I don't have to take it out again when the turbo goes in. I had it out bc I made custom gauge pods, so i hope everyone is ready for a lot of pictures of the process tomorrow (hopefully).
R350k5
Oct 1, 2015 08:41 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
