Another problem with the supercharger
Old Mar 1, 2008 | 03:32 AM
cchaorule's Avatar
so after i figured out what happened after i bottomed out.. it was just a leak in the oil fuel line.. no biggie got that fixed car drives fine.. today i drove around for 30 miles and as i was heading home..as i was stopping to a stop light... my car stalls when i was in neutral... i start it up.. it was fine.. then i kept driving.. when im in 1st gear.. the RPM keeps jumping from 0-1000.. then it would eventually stall.. i have no idea whats wrong cuz it was fine the past couple of days.. and then i realized the Check engine light is all of a sudden gone.. and when my car is in neutral the car idles really wierd.. jus always seems like its about to stall.... what could be wrong this time??
Old Mar 1, 2008 | 04:21 AM
cchaorule's Avatar
okay so i jus went and tried to start my car again.. it starts and idles normal.. i rev it up to 3000 and then it just drops to 0 and stalls...
Old Mar 1, 2008 | 04:39 AM
JJJAAASSSOOONNN's Avatar
mas air flow sensor
throttle chamber
vacuum leak
could be those...
Old Mar 1, 2008 | 03:47 PM
Mjohn's Avatar
I had a similar problem on my car. Took it to the dealer and they had to replace the Throttle chamber. Although your car has a SC and my car only has cosmetic mods...for now =] it might be related to your performance upgrades. Not sure. But the symptoms match.
Old Mar 1, 2008 | 03:51 PM
booger's Avatar
Check your vacuum lines running to your BOV and to the SS box
Old Mar 1, 2008 | 06:01 PM
cchaorule's Avatar
does this sound like a tuning issue or a installation issue?? both my instaler and tuner offered to take a look at it for free.. but not sure who to take to first
Old Mar 1, 2008 | 10:43 PM
cchaorule's Avatar
okay just took my car to the tuner.. he says the car is running at 0 boost..so my supercharger is blown??? he says he doesnt know the problem.. i am taking it to my installer tomorrow.. but he says my car is driving as if it was na.. the bypass valve is also not working.. i had it boosted for 2 days and the kit has 4k miles.. how can this happenn??? what can be wrong..
Old Mar 1, 2008 | 11:28 PM
booger's Avatar
I would say a vacuum hose came off or something simple . Take it to the installer.....Im sure he'll find the problem with in minutes
Old Mar 2, 2008 | 12:30 AM
cchaorule's Avatar
think so?? my tuner thinks its definately my blower thats broken
Old Mar 2, 2008 | 08:40 AM
booger's Avatar
If it was the blower .....you would hear [ in most cases ] a very loud metalic noise . The blades hitting and scraping or a granding of gears. If the seals were shot , you would have oil coming out of the blower .
But again....its hard to say over the internet
Old Mar 2, 2008 | 09:13 AM
clifftrail's Avatar
Do you even know if the impeller is spinning?
Old Mar 3, 2008 | 01:32 PM
Deang35c6's Avatar
Sounds like some piping got disconnected
Mad A
DFW Classifieds
Mar 28, 2016 11:25 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
mattdg35
Sep 14, 2015 11:28 AM
ChrisAult2004
Sep 11, 2015 10:33 PM
