turbo...with or without cat ?
Old May 7, 2008 | 12:46 PM
BAD430BENZ's Avatar
fi kits that have the option of with or without cats...whats the difference than the obvious cat issue ? power difference ? install difference ?
Old May 7, 2008 | 01:04 PM
XKR's Avatar
XKR
If you are looking for big power....using the cats will cause alot of heat robbing you of power. If you are looking for less than 450 whp ...I dont see a problem using cats. High Flow cats would be my choice if I had to use them.
Old May 7, 2008 | 01:39 PM
BAD430BENZ's Avatar
so there really is no difference in the setups other than the actual cats themselves...without is probably better if there is a possibility of going big power
thanx
Old May 7, 2008 | 03:59 PM
Canadian's Avatar
Canada, eh?
I was told you should get a little quicker spool of the turbos if you are using test pipes.
Old May 7, 2008 | 06:34 PM
superchargedg's Avatar
Well after about 6 months of the greddy twins they burnt up my stock cats with more smoke then i have ever seen come out of an exhaust before.The burnt out cats have ruined my borla exhaust and the smell is awful.I am now running test pipes and soon a greddy tic exhaust.
Old May 7, 2008 | 10:55 PM
urban's Avatar
I am running test pipes and it makes a huge difference in power. I picked up another 20rwhp. I had HF cats before.
Old May 7, 2008 | 11:52 PM
ttrank's Avatar
Grocery getter
Test pipes FTW! Faster spool and more power.
Old May 8, 2008 | 09:54 AM
BAD430BENZ's Avatar
test pipes it is....thanx guys for all the info
Old May 8, 2008 | 10:30 AM
350Zed's Avatar
Wink
I prefer my turbo with cat...
Old May 9, 2008 | 02:44 AM
Deathmage's Avatar
i have a 3.5" downpipes that can fit over some people's heads.. stock cats will not release backpressure efficiently. testpipes will make your car reek like hell, but all worth it.
Old May 15, 2008 | 04:15 PM
G-Mony's Avatar
I had 3.5" test pipes....but the smell and noise was too much so put the stock cats back on.
Im sure I lost some power but I couldn't really tell the difference driving.
Old May 15, 2008 | 04:18 PM
EricIsKlumzyee's Avatar
its up to a 20whp difference from stock cats to straight pipes.. confirmed by a bunch of tunners (they all screamed "test pipes" at me when I asked them the same question haha)
Old May 15, 2008 | 04:19 PM
urban's Avatar
I had HF cats and burnt through them in about 4 months
Old May 15, 2008 | 04:30 PM
meooowww
