G35 APS TT, GTM build finished (56K NO WAY)
Old May 9, 2008 | 12:58 PM
boomergt's Avatar
I am fairly new to the community.. I have a 2003 G35c that I just finished motor build with an APS TT kit..
I also posted this on my350z.com.
***Let me know what you think.....
I added a ton of new mods... Here are some pics of the build progress..
GTM built short block with Eagle Rods and Arias ED Pistons
Competition Valve Job with Brian Crower Stage 2 Cams and JWT valve spring and shim kit
Cosworth Stopper Ring Headgasket VQ35 96mm
DeatschWerks 600cc Injectors
Forge Actuators - Blue Springs
ARP 2000 HeadStuds
Koyo Racing Slim 350Z/G35 Radiator 36mm core
NGK LFR6AIX-11
Revup Oil Pump
Defi Water Temp, Oil Pressure, Boost Gauge
Defi Link Controller
Lotek 60mm Pillar Gauge Pod (willow)
Dual Bank PLX Wideband (DM-200 + SM-AFR Combo )
Optima 34R
For a full list of mods check the link below.
http://www.cardomain.com/ride/3036738
Here is a pic of the car as we were moving it from storage.
I put 3 of the gauges in the pillar and one replaced the clock.
boomergt's Avatar
Alright now for the tuning info...
The tune went pretty well.. The car made 505WHP and 505TQ....
If you look at the dyno chart you will notice a couple dips in my dyno this is because of the unichip ems..
I might in the future look at another EMS (fcon or haltech) to get a smoother tune.
I think I will be happy with this power
Dyno Chart
Old May 9, 2008 | 01:08 PM
GreenGoblin's Avatar
The goblin resurrection
looks good
Old May 9, 2008 | 01:11 PM
hankookstyle's Avatar
so is your car DG or OB?...
nice ride btw.
Old May 9, 2008 | 01:13 PM
boomergt's Avatar
OB... The one pic with the engine in the car, it is covered in dust..
nice ride btw.
Old May 9, 2008 | 02:10 PM
EricIsKlumzyee's Avatar
Nice, Congrats! =)
- Eric
Old May 9, 2008 | 02:54 PM
6spG's Avatar
Very nice! Need more pics of the car.
Old May 9, 2008 | 03:04 PM
boomergt's Avatar
I will toss some more up in a few days.. My car is at the body shop right now.
Old May 9, 2008 | 04:08 PM
ukgt's Avatar
I have a similar aps TT build with cosworth built motor, APS extreme fuel kit, Aps 3" exhaust and down pipes etc. Why did you change the oil pump ? have you heard of any breaking down. Or did you change it just for the high flow rate, im guessing a higher pressure pump will cause seals to leak correct ?
Sorry just asking this as i was deciding whether to change my pump before the engine goes back into my car but been told by many 350z people with big power that its not needed.
Old May 9, 2008 | 04:19 PM
boomergt's Avatar
I had to replace my oil pump due to the stock motor blowing.. The revup oil pump is made for the higher reving motors... And with a built motor and the more stress it should be more reliable.
Old May 9, 2008 | 04:24 PM
ukgt's Avatar
I have the non rev-up motor. So had you heard of any failures ? sorry to press but like a lot of things im getting mixed messages so i always like to speak to people that have done similar builds.
Thanks.
Old May 10, 2008 | 01:23 PM
Zivman's Avatar
Thanks.
If you are going to replace your oil pump I would just buy the rev-up. If you don't plan on replacing your pump just leave it. The revup will provide no noticable anything. It is designed to handle slightly higher revs and therefore is theoretically a stronger, better pump. As a result if a new pump is needed, why not get the revup?
Old May 10, 2008 | 02:18 PM
ukgt's Avatar
Cool, thanks for that
Old May 11, 2008 | 08:33 AM
superchargedg's Avatar
Looks like a very nice build and you gotta love 500rwt at 4000 rpms.
Old May 11, 2008 | 11:55 AM
Sponger's Avatar
6MT Brembo Coupe
Good stuff. Looks like you had a lot of room to work with
