Ideal boost, backpressure, and timing?
Old May 27, 2008 | 11:35 PM
GreenGoblin's Avatar
The goblin resurrection
seems that you know where your problem is, but in all honesty if you dont like the sound and you only have about 10 hp to gain b4 putting ur motor in danger, what is the point of changing the setup?
Old May 28, 2008 | 01:21 AM
Hexxum001's Avatar
Originally Posted by BadBoy06
open her up a bit with the Fast Intentions 2.5..you will still keep the stock tone but a little deeper..imo
That's exactly what I did. I went from HKS Hi Power to GReddy Evo TT to Fast Intentions. It's almost stock looking and sounds slightly louder/deeper than stock.
Old May 28, 2008 | 04:55 AM
zazaracing's Avatar
Team Transport Member
get some test pipe and a custom mid pipe.... but you really gonna kill the mototr with all the back pressure its not going to last long either with you pushing 400+ on stock block
Old May 28, 2008 | 10:10 AM
aero's Avatar
Originally Posted by str8dum1
At 400 hp, i doubt your timing is that tame.
just post up your timing map from the UTEC and we can quickly tell ya how much room you have to play. if its only 13-14 degrees at the top, you can easily add another 5-6 degrees.
I would if I could man. Unfortunately, I'm retarded when it comes to car electronics. Ironically, if it were an airplane I could probably pull anything I want out of it.
That's a great point. I'm finally getting a VB upgrade as we speak (on my new unit installed by Infiniti), so maybe this is the perfect point to stop and be happy with it. But on the flip side...
Originally Posted by zazaracing
get some test pipe and a custom mid pipe.... but you really gonna kill the motor with all the back pressure its not going to last long either with you pushing 400+ on stock block
A part of me is scared that I'm making "dangerous power", that my boost and timing are purely the result of the bottleneck in the exhaust. If I open it up and drop it to say 12 psi, with the timing advanced just a little bit and that exhaust gas getting out, seems like it would be more stable. Maybe I shouldn't even be considering extra power, just focusing on increasing the throughput.
There is possibly a catch to all this though. My 403 whp was measured at 6800 RPM in tiptronic (slightly raised rev limit via reflash). I've been under the impression (told) that in drive, you're stuck with a hardcoded 6600 RPM limit. If that's truly the case, on any given day I may only be pushing about 380 whp, because I typically cruise around in drive.
Old May 28, 2008 | 03:26 PM
G37Rider92649's Avatar
everybody took the words out of my mouth already, good info guys
Old May 28, 2008 | 04:57 PM
SDGeneralCounsel's Avatar
The fast intentions does not keep the stock tone. It makes your car sound like an old FBody slowmarrow. If you want to keep the your stock tone, but still want to open it up, you should go for the Nismo exhaust with high flow cats, or the Fujitsubo (the same as the Nismo one) that Mark recommended above.
Old May 28, 2008 | 05:07 PM
SDGenius's Avatar
^+1 Fujitsubo make's Gade A stuff, it's pretty much a better version of the Nismo(they make the Nismo too). louder, lighter and better flow. not to mention it looks less stock than the Nismo and bolt's right on.
Old May 28, 2008 | 08:28 PM
aero's Avatar
You guys think that previously posted clip of the Fujitsubo is representative of the real sound? It's on a Z, and there's something in the background, could be a dyno, or maybe even an SC.
http://www.350z-tech.com/w/images/b/...Clip_Steel.mp3
Found one on youtube of a G35. High RPMs sound sick.
It's just so damn hard dishing out a grand for something you spec'ed out on youtube! Sounds like you guys have all been down that path before, since some of you have gotten 3 exhausts!
Old May 29, 2008 | 12:06 PM
Q45tech's Avatar
Measure the back pressure at various points at WOT HP peak rpm to calulate how much you are losing.
Tap new threads in exhaust to connect before and after 1st cat, then after last cat [to analyse muffler system].
http://www.toolfetch.com/Category--A...-OTC7215.shtml
Old Jun 14, 2008 | 07:25 PM
aero's Avatar
Hey guys, thanks for the tip! It was like finding the holy grail, but I finally found a vendor with a fuji in stock. Fuji + vortech = pure sex. It definitely sounds different than all of the NA clips. It has a deep rumble at low RPM (*almost* like a V8), not obnoxious at all, and then at high RPMs the thing just screams, sounds like a ferrari.
Old Jun 14, 2008 | 07:58 PM
Sbeck's Avatar
Congrats on the new purchase. I'm sure it sounds great
Old Jun 15, 2008 | 05:52 PM
SDGenius's Avatar
AWSOME choice, can't wait to hear the clips
jsimonk
Dec 22, 2023 03:49 PM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
nervseele
Engine - Exhaust
Jan 17, 2016 01:02 PM
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
