Difference between supercharging and turbo G35?
Go to the force-induction section...There are a lot of threads there you can read and research...This topic has been discussed many times or you can use the search button...Hope that helps...
Quick answer: turbos will ultimately yield more power + cost more. I'm not sure what most superchargers put down, but I'm guessing 400whp is the
upper end of what they put down. I don't recall seeing a 500whp supercharged VQ, but anything's possible if your pockets are deep enough.
I would recommend a turbocharger. Superchargers require synthetic blinker fluid and oil changes at least every 200 miles or so. Much more maintenance. With a turbo, you can use normal blinker fluid and the turbo automatically cleans your oil so you actually never ever have to change it. Any other questions, please feel free to let me know.
Originally Posted by azzkikr
thanks Calla
no i've done at least 32 turbo installs on my car and the longest it ever took me was 1 hour. i think my record was somthing like 13 minutes. but i didn't change any of the fuses in my wheel well so the car ran like crap afterwards.
