Gauge Pod for Steering Wheel
Old Aug 16, 2009 | 03:40 PM
MikeGrote's Avatar
Originally Posted by sliderg35
I agree with TTrank... If you use velcro to hold your gauges together you car will look like crap. It's a great car and reasonably expensive - pay the bucks and make it look like it was originally built that way.
i want it all in the cubby so its hidden, i dont like to have all that clutter out in the open all the time.
Old Aug 16, 2009 | 07:52 PM
ttrank's Avatar
Grocery getter
Originally Posted by MikeGrote
nice work man! would you be interested in making a simple one that would fit in the cubby of an 06 coupe for just one gauge? i would velcro two dyno tune digital gauges on each side so only one hole would be in the middle.
mike
Sure. Just something to fill in the center area, like a box? Tucked down under facing up or with a gap in the front?
Old Aug 20, 2009 | 11:54 PM
MikeGrote's Avatar
pm'd you
Old Oct 5, 2009 | 05:48 PM
SR20DETDatsun's Avatar
Thumbs up
IMO the best place to put gauges on the G is here:
Take a bit of work but comes out very nice.
Hey PM me. I wanna talk about doing some custom Gauge Pod stuff for my Datsun 510. Thanks......
Old Oct 5, 2009 | 06:05 PM
ttrank's Avatar
Grocery getter
Sure, just let me know what you are looking for. Pics of the parts you want modded or any examples you have will help.
Old Oct 5, 2009 | 07:57 PM
I need a 4 gauge (2-1/16") pod/panel setup.
I want to replace my current (home made) upper consol (pic 1) with a molded, angled towards the driver, 4 pod console that fits a boost control module too. (you can see the silver rectangular guege in the previous pic) I want 4 across and the Boost module centered below it.
I want it to come from the bottom of my dash and seamlessly flow from into my bottom consol and look like a "stock" setup. You can see where it separates in pic 2 where there is a black angled lower consol and then the upper leather wrapped boxy thing with two elec. gauges on it. Name:  510_9.jpg
Where are you located? This would obviously be better if you were near so that you can physically look at my setup and take dimesions.
I have MANY ideas but just don't know how to do this and make it look great.
At first look How would you go about this?
Thanks in advance....
Old Oct 10, 2009 | 02:24 AM
kennymo's Avatar
ttrank would i have to send you my bezel to make me one like yours?
Old Oct 10, 2009 | 01:12 PM
ttrank's Avatar
Grocery getter
Yes, unless I can get a core to work on and then have you send me yours when you get the other one.
I have a core for the 05-06 sedan/05-07 coupe interior right now but don't have an 03-04.
Old Oct 10, 2009 | 01:18 PM
ttrank's Avatar
Grocery getter
I want to replace my current (home made) upper console (pic 1) with a molded, angled towards the driver, 4 pod console that fits a boost control module too. (you can see the silver rectangular guege in the previous pic) I want 4 across and the Boost module centered below it.
I'm in Phoenix, AZ.
If I understand right, you want something to replace that leather wrapped panel you have now with 4 gauges angled toward the driver and the other equipment below it?
This part would have more of a sweeping flow from the lower console up to the bottom of the dash to have a more oem-like flow?
Something like this would be very tough to build without having the car available to test fit the part and figure out angles for the gauges. If you were local it would not be too tough to build but this isn't something I would want to take on without having the car close. If it didn't turn out just right I would be upset (as would you).
Old Oct 14, 2009 | 06:20 PM
I'm in Phoenix, AZ.
Thanks for the reply.
I totally understand. I am kind of working on a consol myself but I doubt it will have the finished look that yours has.
I used a wood backer with 2" PVC pipe, foam and bondo. What can I use to smooth out all the pits and make all the
surfaces smooth?
What could I do as far as coverings to get an OEM look to it?
Here are pics.....
Of course it needs to be finished and I don't think it's that bad for my very first stab at this sort of thing.
It will have sides on it but if it could have some "shape" to the side instead of a flat board, that would be better.
Any advice/comments/constructive criticism would be welcomed.
Old Oct 15, 2009 | 12:27 AM
Lightbulb 510 Center console
Hey again.
Here are some pics. This is not finished of course and it needs lots of shaping and hole filling still but I don't think it is a bad start for my very first time trying something like this.
This will replace the leather center section of my consol.
It contains 4 pods and a sunk in pod for my boost control.
Take a look......
Of course I am going to add sides to it but I would like some shape instead of straight or angles sides.
The gauge pods hold the gauges perfectly. They fit nice and tight. The Boost Control pod fits perfectly too.
What else can I do with this?
Thanks for all of your time.....
Old Oct 19, 2009 | 06:05 PM
Question
Any comments or suggestions?
Old Oct 19, 2009 | 08:18 PM
ttrank's Avatar
Grocery getter
I just saw you posted. I can't see the pics at work and will have to try and get on once I get home.
Old Oct 19, 2009 | 08:19 PM
ttrank's Avatar
Grocery getter
Oh and for anyone else, I just picked up a clock finisher for the 03-04 and am going to build a gauge pod like mine and put it up for sale. Should be next month some time. I also have one for an 05+ that I need to do.
Old Dec 18, 2010 | 12:40 AM
  #30
drifterxG's Avatar
I know it's been a while, but do you still do this? I have an '05 Sedan.
