Vortech kit questions
Old Sep 5, 2008 | 04:39 PM
Realtor's Avatar
I was thinking of buying a used vortech kit off of a 350Z. Has anyone done this and had problems?
With the complete kit do I need to upgrade injectors or should the vortech additional fuel pump be enough?
Also what about oil, did you guys tap the stock oil pan or just buy a oil pan spacer to solve that issue?
Thanks for any input on the vortech supercharger kit install and any other info you can share that you would not do again or buy before install etc.
Old Sep 28, 2008 | 12:24 AM
SoCalTed's Avatar
Here's a good thread to check out
http://www.my350z.com/forum/forced-i...questions.html
Cheers, Ted
Old Sep 28, 2008 | 12:26 AM
express705's Avatar
i dont suggest buying a kit off of a 305z. i am not sure the fitment is 100%, but i MAY be wrong. also, make sure its a non revup or a revup, whichever matches your car.
if i were you id get a tuner kit. its tuner friendly, and you can upgrade anything you want.
as for oil, i tapped the block. other options are avalible, such as getting an oil pan spacer, or getting the new V-3 blower, which is self contained.
the install isnt as bad as it sounds. as long as you have the tools, some knowledge, and extra hands to help, you should be fine.
Old Nov 22, 2008 | 01:59 AM
crashnburn's Avatar
i just had mine installed and it was a kit for a 350z... only difference i think was i had an extra intercooler pipe.... mine install took longer than it should have but im happy with it and already ready for the 3.12 pulley
Old Jan 27, 2009 | 11:13 AM
ska12's Avatar
hey how do you take the belt of the vortech sc. so i can replace a idler pulley?
Old Jan 27, 2009 | 04:53 PM
str8dum1's Avatar
loosen (but dont remove) the 14mm nut on the idler pulley then under the car loosen the 12mm idler adjuster nut. the serp belt will become slack
Jusseth
Sep 13, 2020 12:25 PM
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
Tukeeg35
Engine - Intake/Fuel
Aug 21, 2015 04:19 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
