just got my vortech
just got my vortech
I just got my vortech and is scheduled to get installed next week... i was wanting help on what other mods would help me get to the 400hp and 370trq or more.. i have a 5/8" plenum spacer and greddy evo2 exhaust....btw its an 03 coupe
Really Needs a Life
i dont own a vortech, but i did alot of reasearch about it before i decided to go FI, but your gonna wanna get the *correct me if im wrong* 2.87 pulley, which should get ya close to where you need to be.. but i could be wrong.. vortech guys will know better than i would
awesome man... thanks... i got a plenum spacer and greddy evo2 exhaust already...im going to buy the pulley now from vortech i guess...its only 80 bucks..... the kit came with a walbro 255...so i guess ill look for some cats and i got friends that use meth kits on their evos so i can get one from them...... awesome.....
btw what size injectors do i need? dont want to have to do something twice if i can help it....
time out. lets go over this.
i ASSUME you got a full kit if it came with a fuel pump?
if you did, not much you can do.
heres the deal with the pulley.
the vortech as it is isnt made for smaller pulleys like the 3.12 or 2.87. thats how i ****ed up my blower. you need upgraded bearings and other internals to handle the overspinning of the blower with a smaller pulley.
my supporting mods:
440cc injectors
custom plenum
test pipes
hks exhaust
utec
3.12 pulley.
im making 370 whp at 9 psi.
hope this helps. PM me with any questions you might have.
thanks.
my supporting mods:
440cc injectors
custom plenum
test pipes
hks exhaust
utec
3.12 pulley.
thanks.
so i would need to send my blower to vortech to get it upgraded to run the higher boost pulleys?
i have never taken my car to the track. i do plan on it.
vortech CLAIMS your warranty is void if you upgrade the pulleys.
i mean.. it tears up your blower. look at mine.. perfect example.
Originally Posted by crashnburn
lol...im sorry that sucks but the way u set that up was funny.... so i take it u changed to a smaller pulley and blew up ur blower... what did u do to fix it?
so i got a 3.12, blew up the blower.
i got in a little argument with vortech because my blower was rebuilt 2 months ago. they are currently replacing my blower with upgraded internals.
Just to clear things up, you don't need to send your sc to Vortech to get anything upgraded with a smaller pulley. You just need to know the max rpm that you can push your sc too. For instance, on my G, the max impeller speed of my sc is reached at 6800rpm. Vortech has a calculator on their site where you can determine what the max rpm is with your setup before you start overspinning your sc. As long as you don't exceed that max rpm, you should be fine.
http://vortechsuperchargers.com/supp...d%20Calculator
get the 3.12 pulley. keep the stock FMU, ss box and inline fuel pump. get someone who knows what the heck they're doing with an SS box. then you'll make HP like i did. done
