HKS Camp 2 users
Old Nov 21, 2008 | 02:46 PM
GreenGoblin's Avatar
The goblin resurrection
HKS Camp 2 users
I was curious what parameter you were watching out of the 6.... I also bought the cable to connect it to the Fcon V pro but I do not see the purpose.
Old Nov 21, 2008 | 06:36 PM
I know a couple of you guys have this....
Old Nov 21, 2008 | 07:46 PM
XKR's Avatar
XKR
I maybe wrong....but I though the Camp2 was suppose to be connected directly to the Fcon Thats the way mine is hooked up.
Old Nov 21, 2008 | 07:55 PM
It can be hooked up to the fcon or with out the fcon.... I have it hooked up with the fcon. What sensors do you have yours keeping an eye on?
Old Nov 21, 2008 | 08:22 PM
rookie's Avatar
OBD-II and IF box
Speed (using offset to correct for shorter tires)
Timing
OBD-II water temp sensor
IF boost or whatever I want to change out too.
IF oil temp
IF oil pressure
Defi fuel pressure, boost gauge, and innovate on the pillar
Old Nov 21, 2008 | 11:42 PM
terrycs's Avatar
1) Air/Fuel (A/F)
2) EGT (IF EXT_T)
3) Oil Temp (IF OIL_T)
4) Oil Pressure (IF OIL_P)
5) Water Temp (WATER)
6) Boost Pressure (IN_MANI) or Fuel Pressure (IF FUEL_P)
Old Nov 21, 2008 | 11:54 PM
Mr_pharmD's Avatar
SOrry for the newbie question but if I have the vpro navi doesn't it display the same stuff as the HKS camp?
Old Nov 22, 2008 | 12:13 AM
terrycs's Avatar
Sure, but the F-CON Navigator doesn't have nice graphics and is not really readable on the road while driving. I also don't know if the navigator has alarm capabilities like the CAMP2 does.
Old Nov 22, 2008 | 01:46 AM
Mr_pharmD's Avatar
Hey terry, do u know if they have an option for oil temperature? I tried lookin at the manual but everything is in japanese.
Old Nov 22, 2008 | 05:56 AM
XKR's Avatar
XKR
For now I have it set to MPH, A/F and I forgot the other one........Sharif is going to install Oil Pressure, Fuel Pressure and Oil Temp......those I will monitor.
Old Nov 22, 2008 | 05:59 AM
XKR's Avatar
XKR
This thing can monitor anything a regular gauge can monitor. If the Camp2 came out when I was first building my car....I would not have installed regular gauges.
Old Nov 22, 2008 | 11:31 AM
I agree I would have installed this only
Old Nov 22, 2008 | 02:02 PM
terrycs's Avatar
Yes, but you need a sensor and their interface (IF) module. Details here:
http://www.hksusa.com/info/?id=3474
Old Nov 23, 2008 | 05:26 AM
heyitzalex's Avatar
from what I heard, the next software update for the camp2 (supposed to be available this month) will allow you to monitor more things (oil pressure, etc) without the interface unit. Also, you will be able to switch fcon maps with the camp2. the current software version was supposed to allow map switching, but i guess the developers at hks got themselves a bug
Old Nov 24, 2008 | 12:56 PM
I cant wait for that update then
