E-Manage Ultimate ???
Old Nov 25, 2008 | 01:51 AM
SILVERSURFERG35's Avatar
Exclamation E-Manage Ultimate ???
I am currently running the e-manage ultimate on my N/A 06 G35 . Just purchased Greddy TT kit and I am wondering if anybody is currently running there turbo car with it and what type of numbers and reliability are they getting with it . Thanks for any info you may provide .
Old Nov 25, 2008 | 01:56 AM
G37Rider92649's Avatar
I have no idea why you're running an E-Manage with your NA car If I was NA I'd just get a flash and call it a day. Since you're going TT I most definitely DO NOT recommend the E-Manage, that system is crap In my opinion it's the worse engine management out there, even if you think you got the tune correct, sooner or later down the road something bad will happen and it will just be a head ache and a waste of time. So take my advice right now, if you're going TT and thinking of boosting big, don't use the E-Manage, or you WILL switch it in the future, trust me.
Old Nov 25, 2008 | 02:29 AM
Appreciate the info !! I was hoping that someone would tell me that I would be good ! I already knew the answer though !! LOL Thanks !
Old Nov 25, 2008 | 02:33 AM
Mr_pharmD's Avatar
why do ppl trash talk when they have no clue from experience? did u ever try the EU or driven in a car with the EU? I bet your knowledge of the EU are just here say.
Now, my side of the EU... the EU is like every other piggyback out there. I have it and have used it for 2 years now without any issues. I;m putting down 420whp/360lb tq and it's my DD. The EU controls everything you need just like the Utec would but at fractions of the cost. If u know u will not be boosting over 12 psi then u can either stick with the EU or any other piggybacks out on the market. Now, if u are wanting to make over 450whp I would recommand getting a standalone EMS like a FCON.
Old Nov 25, 2008 | 02:44 AM
2slo2bfurious's Avatar
Nothing wrong with using an EU NA, its not much more than a reflash anyways.
If you really really want to keep the EU, it will do the job. I'd rather get at least a UTEC though. Granted the EU interface is easier to mess with, the utec just gets the job done a little better... its piggybacks vs. "parallel" management, obviously the latter will be preferred.
Old Nov 25, 2008 | 02:49 AM
Thank you to sir !! Thats good info ! This is exactly why I asked the question !! Everybody dogs the Eu ! Just wanted to know if I needed to buy a Utech or if I could just roll with what I have ! Thanks again !Mr.pharmd !!!
Old Nov 25, 2008 | 11:01 AM
GreenGoblin's Avatar
The goblin resurrection
The ultimate will be fine, if it was the blue then I would tell you to trash it
Old Nov 25, 2008 | 04:35 PM
sliderg35's Avatar
I've bee using the EU since I went TT over a year ago. It is my DD and I have not had any issues either.
Old Nov 25, 2008 | 10:32 PM
Thanks guys for all of the good info !! This is the first time that I got good info good and bad ! Very appreciated from all who have taken time !
Old Nov 26, 2008 | 03:31 PM
sharif@forged's Avatar
We did dozens of EU tunes back before the UTEC came out. It definately works, but you usually get a little more consistent result with the UTEC. And on an FI car, there are some very nice safety features of the UTEC, such as knock detection and overboost cut, that can prove useful
Old Nov 26, 2008 | 05:21 PM
FI'ed G's Avatar
+1 no other Piggy back and no Reflash (sorry Uprev fans) can give you this. ECU stop monitoring Knock/detonation after 5000rpm, it's kinda stupid coz when racing/drag you stay above 5000rpm 98% of the time (unless you are a a Pu$$y and shift before 5000rpm). I have never hit overboost cutoff but it's comforting to know I'm protected if my Wastage/BCS fail..
Old Nov 26, 2008 | 07:09 PM
Uh huh, E-Manage is still a Piece of shiet IN MY OPINION then haha Fcon Vpro ftw!
Old Nov 26, 2008 | 09:33 PM
thom000001's Avatar
Others do too.. ProEFI 48 is piggy back and has these....and more.
just a fyi. not meant to hijack
Old Nov 26, 2008 | 11:33 PM
FI'ed G's Avatar
FCON Vpro is technically considered piggyback too ProEfi, Haltech, Vpro are considered standalone coz they dont rely on the ECU values to run the car. Look at the price difference, point me to a shop that can do a ProEfi that will sell me the unit with harness for under $1500 with install and Tune? If you want to be picky then no Piggy back that cost less than $1000 offer knock control!! happy now? Last time I checked Haltech dont offer active knock control and Vpro knock amp is an add-on so it will cost your more $$$.
As far as I know there is no full Standalone replacement for our ECU, so if you want to be a picky then every ems out there available for our car does still piggy back to our ECU. GurgenB has been using the Motec but not sure if it actually replace the ECU but our ECU control many other function in our car that it is almost impossible to totally remove it, hence they all piggy back into it. Haltech, ProEfi Vpro all cost close to $3k or even more if you consider Vpro + knock Amp with install and a full tune.
