APS TT issue
Old Jan 13, 2009 | 01:21 PM
escobar929's Avatar
any codes?
Old Jan 13, 2009 | 02:12 PM
ttrank's Avatar
Grocery getter
Originally Posted by G35zkyline
make sure there is no water going thru your firewall into the utec i had that issue
I have that issue but can't find the source anywhere. Where was yours coming in from?
Old Jan 13, 2009 | 02:54 PM
amf25's Avatar
computer did not pull any codes. so far the fuel system checks out, pumps working, everything connected, no leaks. No spark at the factory test lead, so they're going after the crank sensor, then the ecu.
will the car die suddenly if utec is involved? how would you know if moisture is in it?
Old Jan 13, 2009 | 03:51 PM
ttrank's Avatar
Grocery getter
When mine got wet the either the O2 readings went off or the injector control was off because it was going lean - rich - lean - rich etc. Depending on how wet, etc it could just shut down too.
Old Jan 13, 2009 | 05:05 PM
sliderg35's Avatar
I had trouble when water was coming through the rubber grommet through the firewall. It turned out that the turbo installers had just pushed it back on - they didn't actually seal it properly. It ran really rough and the A/F readings were all over the place. Once the grommet was put back on properly - no more trouble.
Old Jan 14, 2009 | 02:12 AM
urban's Avatar
I had that issue this time last year where water was coming through the firewall and messing with the Fcon, it would bog and then run fine and then bog again, only happened when it rained so I took it down to GTM and they found where the water was seeping in and fixed it.
That was almost 40k miles ago
Old Jan 14, 2009 | 03:16 PM
ttrank's Avatar
Grocery getter
So yours was the big grommet facing up?
Mine is somewhere else...
Hmmmm I guess it is time to go searching again.
Old Jan 15, 2009 | 04:11 PM
sliderg35's Avatar
Yep, the big one that everything goes through. When I was trying to figure out what was wrong, I noticed that whenever water hits the windshield, it will flow directly down on top of that grommet. Kind of a bad place to put it really - but when it is sealed it seems to hold just fine.
Old Jan 15, 2009 | 08:38 PM
Hexxum001's Avatar
haha! I had the same issue. Water got in back at the end of 07/beginning of 08 when we had that period of time where we had a lot of rain here in L.A. It was like a month of almost continuous rain. Anyways, rain got in through the firewall cuasing a short and ended up blowing two of my coils. But GTM took car of it for me and I haven't had an issue since. *knock on wood*
G35Rican
Jul 31, 2024 01:37 AM
cmesidewayz
Sep 29, 2015 09:28 PM
socaldavid
Sep 5, 2015 04:35 AM
kevintandmd
Sep 3, 2015 06:41 PM
UT G35
Sep 3, 2015 03:58 PM
