belt noise
Old Apr 16, 2009 | 08:03 PM
ska12's Avatar
belt noise
Ive heard a lot of people has problems with with belt noise on their vortech system. I have an 03 and the belt squeeks loud until it gets warmed up then it goes away. Does anybody know of a belt i can get for it that wont stretch or that dosent squeek at all?
Old Apr 17, 2009 | 12:38 AM
str8dum1's Avatar
a proper length and tensioned belt wont make any noise.
you are obviously missing one of those 2 things
i've used napa belts (rebranded Gates) exclusively and never had slip nor noise
Old Apr 17, 2009 | 09:11 AM
ska12's Avatar
whats your horse power. And what is Napha belts. Like their not the stock vortech belts. If not where can i get it.
Old Apr 17, 2009 | 09:48 AM
kzanard's Avatar
9 times out of 10 if your belt is squeaking, it needs to be tightened. It is normal and belts stretch slightly over time, requiring tightening. Tightening is easy. The biggest PITA of the whole process is getting the plastic panel out of the way because of all the screws. Some people cut a hole in the panel (to allow access to the tensioner bolt) or removed it completely.
Old Apr 17, 2009 | 09:53 AM
ska12's Avatar
My belt tensioner is already tightened as much as it can go and the belt is stretched again. So there is no after market belt made by anyone that wont stretch?
Old Apr 17, 2009 | 02:21 PM
str8dum1's Avatar
you just need a much shorter belt to start with.
Napa is an autoparts store. All belts stretch. thats why they are cheap and easy to replace.
Old Apr 17, 2009 | 11:24 PM
Chef-j's Avatar
1. Take off your belt
2. take it to local Napa
3. ask them little shorter and strong ones
4. go back and put it back on see if they make a squeeze. If do go more shorter.
But do remember, just a keep tighten isn't always good.
Btw, i'm using gates. 80.5" inch with 3.12 pulley
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
