530bb Question
Old May 10, 2009 | 11:57 PM
Canadian's Avatar
Canada, eh?
530bb Question
I need new oil return lines and I'm going to be getting some stainless steel return lines. I just need to know what fittings or adapters I need for each turbo and what size hose is used.
Also looking at the APS oil pan if anyone has one for sale I'll take it off your hands
Old May 13, 2009 | 11:48 AM
Clint@Altered's Avatar
-4an or equivalent for oil feed
-6an or equivalent for coolant
-10an or equivalent for oil return
As the JWT turbos are BB water & oil cooled, make sure to use an oil feed restrictor on each turbo.
Also, we have -10an aluminum fittings for a oil return which bolts on to the GT25 series turbochargers.
Let me know if you need them,
good luck
Old May 14, 2009 | 12:14 AM
Canadian's Avatar
Canada, eh?
Thanks Clint.
I'm just doing oil return, not oil feed or coolant. Here is the flange I was going to get:
http://www.atpturbo.com/Merchant2/me...gory_Code=GTBB
That and a NPT to -10an adapter then a hose to an APS oil pan I'll be getting. I've been getting help from GreenGoblin, and from what I understand I need a -10an fitting to 3/8NPT to go into the oil pan. Do you know if I need a 90 degree or 45 degree fitting on the APS pan? If you have this stuff at prices better/same/close to summitracing I'll definitely buy from you for your help. Hope you can help
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
