spark plugs, TT ?
Old Jun 24, 2009 | 06:41 PM
NNOCENT's Avatar
spark plugs, TT ?
Going through routine maintence since my "Service Engine Soon" light just turned on. Ran codes, came back mis-firing multiple cylinders. I searched in the Engine DIY section, but no dice. And more FI enthusiasts are in here also.
Currently running Greddy Twins @ 10psi.
What spark plugs do you recommend, and what should I gap them to?
Anything else you recommend that would cause multiple misfire?
2003 Coupe - 35,000 Miles - Greddy Twins @ 10psi - Stock Internals.
Thanks,
Old Jun 24, 2009 | 10:15 PM
Glex25's Avatar
Administrator
NGK LFR6A11 Stock#3672
I gap mine around 35
Old Jun 25, 2009 | 07:55 AM
bullitproof's Avatar
i used to get those. I would cause my CEL to come on for about a week or two and then i wouldnt get the light on for awhile. Sent my ecu off to GTM for some "tweaking". No more misfire codes and can pass DE emissions now with no problem.
Old Jun 25, 2009 | 08:14 AM
GreenGoblin's Avatar
The goblin resurrection
I use the NGK one step colder, but the misfire codes are still present, I might get a reflash someday.
Old Jun 25, 2009 | 10:19 AM
Glex25's Avatar
Administrator
Hmmm weird never got a CEL with these plugs.
I had a Utec and now have a Haltech.
What are you guys gaping the plugs to?
Old Jun 25, 2009 | 10:30 AM
str8dum1's Avatar
i didnt even regap my 1 step colder coppers. never had a misfire code at 15psi
Old Jun 25, 2009 | 02:16 PM
I have got a misfire before, but it is not a common occurance.
Old Jun 25, 2009 | 02:43 PM
ttrank's Avatar
Grocery getter
I use heat range 6 NGK copper plugs, gap to 30. My tuner has had two VQ35 cars (1 G, 1Z) come in (that he did not work on) who both had iridium plugs break off in the motor and take out everything including the heads.
Old Jun 25, 2009 | 02:50 PM
ouch!
Old Apr 30, 2011 | 05:06 PM
dan-storer's Avatar
i also have a 04 g35 coupe TT and also running the greddy kit. I have the same random cylinder misfire code that comes up but my car runs smooooooth as can be. A mechanic recently told me that the one step colder platinum plugs are the plugs to go with and to make the gap 5 thousands of an inch (.005") less than the manufacture rating. i just ordered my plugs today, and they will be here on monday.
Old May 22, 2011 | 07:07 AM
nyqueenz's Avatar
Thanks,
Hows your timming? Your air/fuel mixture may be out of balance
http://www.aa1car.com/library/us296.htm
spark plugs..
http://www.importimageracing.com/mm5...&Store_Code=ii
jeffbdye
Jun 1, 2018 03:51 PM
g.spot
May 9, 2016 10:54 PM
KallDay86
Jan 8, 2016 12:42 AM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
