62mm turbo for rear mount application
Old Aug 12, 2009 | 12:51 AM
JuicinJake's Avatar
i have a turbonetics 62-1 turbo from a mustang hellion kit im contemplating using for a g35 diy sts-style kit. i might just buy the rear exhaust/intake piping from sts and get the rest of the stuff myself. my question to you g35 turbo guys is this: do you think the 62mm turbo with .81 a/r turbine housing is too big for a bolt on g35 motor? the max hp goal would be 500rwhp. i know some mustang guys have pushed the turbo to 600rwhp, but thats the max. what is the a/r on the exhaust side of the sts 60mm kit? fwiw the turbo on a stock 5.0 spools at virtually instantly giving full boost at 2800. if i could get all that done by 3800-4000 id be happy. what do you guys think?
Old Aug 12, 2009 | 02:55 AM
Blackbird V35's Avatar
not too big, im running 2 61mm turbos and Sound performance is running 2 62mm
both on 3.5l engines still
Old Aug 12, 2009 | 05:24 AM
2006tt guy's Avatar
it'll take a bit of real good tuning to make sure you have a good powerband but it's not too big of a turbo
Old Aug 12, 2009 | 07:27 AM
JuicinJake's Avatar
my main concern is the exhaust side... on the two 61's u r running, what is the a/r?
Old Aug 12, 2009 | 11:22 AM
GT-ER's Avatar
I think the exhaust side is too big to get any desirable amounts of torque down low. .81 is a T4 and I can imagine the turbine wheel is a P-trim. I would get a .63 T3 housing bored out for a P-trim wheel or get a .58 T4. I personally hate lag and the STS system in it's self is succeptable to lag.
Old Aug 12, 2009 | 11:42 AM
FI'ed G's Avatar
You need to change the hotside to a .58 to make it work. .81 a/r is just way damn big for a rear-mount and you wont hit boost until redline. There was a guy in my350z who used a T67 but had to opt out for a .58 hotside to make the power usable and still manage to hit 600whp.
Old Aug 13, 2009 | 05:17 AM
2006tt guy's Avatar
for my setup the hot side the a/r is .86 and the cold side is .60. and as FI'ed G pointed out you will not achieve maximum boost until redline which is what was screwing my dyno run up. I could hear my car spooling and it could have gone higher but it hit redline. the numbers are still good for dd but when you have something with so much potential you gotta use it. i will more than likely change my hot side to something smaller because on the streets its virtually useless.
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
Duriisimo
Jul 31, 2015 02:21 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
