cog pulley more boost?
Old Sep 14, 2009 | 01:59 PM
ska12's Avatar
i just went to the 2.87 pulley on my vortech and am hoping to see around 430rwhp. But i heard you could get 500 out of the vortech by changing the cog pulleys also, so i was wondering if i did that would it be safe and what other mods would i have to do to support it?
Old Sep 14, 2009 | 04:23 PM
Canadian's Avatar
Canada, eh?
You shouldn't go over 400whp unless you have a built motor, and you definitely will need a built motor for anything 430whp+.
Old Sep 14, 2009 | 04:36 PM
GreenGoblin's Avatar
The goblin resurrection
Canadian is correct in saying that anthing over 400 you should worry about longevity of the motor... However if you did build the motor it accept bigger power, you need to use the calculator on the vortech's website to make sure you are not exceding the impeller speed the blower was rated for.
http://www.vortechsuperchargers.com/...d%20Calculator
Old Sep 14, 2009 | 05:09 PM
Canadian's Avatar
Canada, eh?
Just curious, but what speed is the blower rated for?
Old Sep 14, 2009 | 10:07 PM
ska12's Avatar
yea i fully rebuilt the motor with all forged parts. I did this so i could add more boost with the 2.87, and just wanted to know it it would make a big difference and if it is safe to add different ratio cog pulleys also.
Old Sep 15, 2009 | 03:14 AM
urban's Avatar
Upgrade to the T-trim blower and get a larger FMIC, you may also want to look in to the GTM pulley setup if you don't have it already. Hopefully you have large enough injectors to support the extra fuel your going to require.
Old Sep 15, 2009 | 05:25 AM
Mr_pharmD's Avatar
u wont make 500 with the sc trim.
I have the only T trim without upgraded cog setup or nitrous to get it over 500whp with the 2.87 pulley (12psi). I am now in the process of going down to a custom 2.60 pulley (yes 2.60) in hopes to gain +3 extra psi (20whp/psi). Yes, I know i'll be over-spinning the blower (by 5500) but it will only be secs until it hits 7000 rpm. Also, u wont really be over-spinning the blower to it's max bc there will always be slippage through the serp belt, therefore, u will never reach the max potential rate whp of 800.
GL to the OP
Old Sep 16, 2009 | 10:39 PM
ska12's Avatar
yea got the gtm setup because it was slipping to much but since im still learning about the vortech setup im going to spend some time researching your suggestions.. (the t-trim and larger FMIC) because i dont know what they are. LOL, but thanks for the help.
Old Sep 16, 2009 | 10:43 PM
ska12's Avatar
what is the difference between the stock blower and the t trim? is the t trim just bigger?
Old Sep 17, 2009 | 12:09 AM
urban's Avatar
It's a larger blower. Just google pics of it and you will see the difference.
Old Sep 17, 2009 | 02:45 AM
Mr_pharmD's Avatar
got to love the newbies
search vortech's website for the specs of each blower.
Old Sep 18, 2009 | 02:55 PM
ska12's Avatar
so around how much whp should the t trim give me?
Old Sep 18, 2009 | 08:55 PM
str8dum1's Avatar
500 if you string it out
Old Sep 20, 2009 | 03:36 AM
Mr_pharmD's Avatar
Im at ~540whp now so u may hit +550 on yours
Old Sep 24, 2009 | 01:59 PM
ska12's Avatar
what do u have in urs to be getting 540?
