Werid AC issue after FI install
Old Oct 5, 2009 | 04:36 PM
Need4SPEED05's Avatar
I installed a TN kit with utec and everything was fine for about 2 weeks. I changed the map on my utec and started the car and I heard a small pop and the AC went hot. I put the temp all the way cold to 60 degrees and it gets cold. Any other temperature and it will blow hot. Anyone know what could be the issue? I'm still trying to figure what the small "pop" was but I don't think it was a coolant line. I don't hear any hissing when the car is off. Any ideas?
Old Oct 8, 2009 | 11:16 PM
come on guys. no one?
Old Oct 9, 2009 | 02:30 PM
Augy's Avatar
i had an issue like that not to long ago. the service tech said it was a sensor under the steering the column. it took him 2 mins to fix or just disconnect and re-connect
Old Oct 10, 2009 | 02:29 AM
hmmm... interesting. I did go under there right before it happened so it may be something like that. I'll check it out. Thanks.
Old Oct 10, 2009 | 10:04 PM
silver g's Avatar
I had that issue long before I was boosted. I forget what the dealer did to fix it...it had something to do with the circut board or something behind the radio if my memory serves me correct (sorry it was a long time ago).
Old Oct 10, 2009 | 11:20 PM
N/A Project's Avatar
-2006 IP GT350-
Interesting problem. Please post update if you can find it.
Old Oct 11, 2009 | 12:17 AM
Metalp3n's Avatar
The cover underneath your steering wheel has a vented small area, roughly the size of your thumbs fingernail on the right-hand side (at least thats where it is on my 03 sedan). Behind that is a sensor that controls the AC temperature. Check to see if that is connected.
Old Oct 11, 2009 | 01:30 AM
j 4 lD's Avatar
There have been a few threads about this posted already.
Old Oct 12, 2009 | 09:58 AM
djamps's Avatar
Connect that wire back up under the steering wheel that you either forgot to connect or did so loosely...and you'll be fine.
Old Oct 13, 2009 | 02:24 PM
I won't have time until this weekend. Will keep you guys posted.
Old Oct 13, 2009 | 02:53 PM
ttrank's Avatar
Grocery getter
Did they have to dis-charge your A/C with the turbo install? If so, you could be low on refrigerant.
Old Oct 16, 2009 | 08:17 PM
they pulled my refrigerant and put it back after so it should be the same as what I had. It just seems like its pulling hot air from the heater hoses in when at any temp other than 60 degrees. And at 60 its freezing cold. I'm definitely thinking its some kind of switch or electrical issue.
Old Nov 1, 2009 | 01:03 AM
Well MetalP3n and djamps were correct. It was a little 4 wire square pin that was disconnected located behind the bottom cover under the stearing wheel. Sorry it took me so long to fix it. Thanks for the help!
Old Nov 2, 2009 | 11:07 AM
Tollboothwilley's Avatar
glad you got it fixed...
chinee
Jun 10, 2024 07:48 PM
hdmark
Apr 29, 2019 04:31 PM
RA102223
Aug 15, 2015 09:24 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Ashton35
Jul 22, 2015 09:19 PM
