Anyone still seeing issues with the Cosworth plenum
Old Dec 16, 2009 | 01:40 PM
nyqueenz's Avatar
I may be asking a redundant question however, I just want to make sure if Cosworth correct the problems with this thing leaking under pressure before I have my sent out for powder coating. Don’t wanna find out when it's too late and installed thanks.
Old Dec 16, 2009 | 06:49 PM
gabe3d's Avatar
I got one a few months ago with no issues but another member got one a month after mine and it had a casting issue where the intake couldn't hold pressure.
Old Dec 16, 2009 | 06:57 PM
GreenGoblin's Avatar
The goblin resurrection
I powdercoated mine with no issues. Make sure they do not get the powdercoat on the mating surfaces so that the seal will be good.
Old Dec 17, 2009 | 04:23 AM
nyqueenz's Avatar
thanks guys i knoe there was an issue with this thing under boost with leaking, but i was thinkin after the CF are sealed could you go around the edge wit silicon to make sure no leaks will occur?
i would advice my shop about the PC areas, i got this from latest batch of CW plenums form forge which were back order for like ever.. so hopefully these are new and improved.
Old Dec 17, 2009 | 01:14 PM
bigc's Avatar
Wings Nation
some folks use RTV in addition to the rubber gaskets. i haven't had any problems with mine up to 13psi with just the gaskets & proper torque specs.
Old Dec 17, 2009 | 01:19 PM
I have used only the rubber gasket and gone up to 22lbs and it did not leak, I normally run about 12
Old Dec 17, 2009 | 03:58 PM
nyqueenz's Avatar
cool, i should be seeing boost well above 12-14lbs i just wanna be 3x sure when everything gets installed and ready for tuning.
Old Dec 17, 2009 | 11:24 PM
str8dum1's Avatar
the jury is still oout about the gaskets and meth injection. rtv. blue locktite and fingers crossed seems to be the best solution. hope it works for me when i get a few more bolts in there
Old Dec 18, 2009 | 02:43 AM
bigc's Avatar
Wings Nation
get rid of that bracket on the end cap!!!
Old Dec 18, 2009 | 04:36 AM
gabe3d's Avatar
^ +1 Yup, I give it 4 in operation before it comes loose!
Old Dec 19, 2009 | 01:53 PM
nyqueenz's Avatar
glue it back on with this... if it comes off..
http://www.gorillaglue.com/
Old Dec 20, 2009 | 12:23 AM
Sylvan lake V35's Avatar
+1 on what Rich said, mine leaked at 19psi with meth injection. The end cap bolts all backed out and even after tightening them i couldnt regain a seal and after mentioning to others a few guys checked them and lots of guys had bolts backing out. I used blue lock tight and black RTV sealant along with the provided gasket and that seems to have cured the leaking. Keep in mind mine was polished by cosworth I think they were the most prone to leaking.
Or throw it away!?
G35VSHNG37
Oct 25, 2015 08:43 PM
Tukeeg35
Engine - Intake/Fuel
Aug 21, 2015 04:19 PM
linedr89
Aug 17, 2015 05:11 PM
RA102223
Aug 15, 2015 09:24 PM
deathsupport
Canada
Aug 2, 2015 10:13 AM
