V2 *IDLE coolant over heat*
Old Jun 7, 2010 | 07:11 PM
WINTERDEVILG35's Avatar
Originally Posted by spinna001
Not wrong thread. I was having the same issues as the thread starter! The guy said they will only deny warrranty if you have a plenum installed,flashed the ECU, or do cams and springs etc
cool. well i bled my coolant system and hopefully that fixed my overheating issue but so far no overheating.
Old Aug 23, 2010 | 06:53 PM
Well I haven't updated this thread for a couple months but my car was still overheating after everything I did. I bled it again and this time when it erupted I caught it before it started. I was watching it and while the car was at idle, with the heat on blast, the level rose very slowly with the large bubbles coming out every second or two. I let it do that for a couple minutes then the level was getting to high so I shut off the car. Once I did that it just erupted like it always does.
note: I also applied some redline water wetter to the mix a day before when I changed out my fluid again.
After that I kept the coolant level up on the spill free funnel. It consumed about a quarter to half a container of 50/50 mix.
The next day I was driving my car for a while then I was going through a congested part of downtown (where the speed limit is parking lot speed). I was driving in 1st gear at about 3000 RPM and my car started to overheat. Then I got back on the main road going about 60mph and it stopped overheating and didn't overheat again that day. Ever since then it still hasn't overheated. I may have to bleed it again and maybe do the same exact thing I did before and keeping a careful eye on the coolant level in the spill free so no air gets pulled in.
If anyone is having the same problem then this thread will help out a lot.
Thanks for all the input from everyone and I'll post again if she overheats.... (knock on wood).
MrIP35
Oct 25, 2015 11:13 PM
BradMD_96
Oct 6, 2015 09:31 AM
Usman Ali
Sep 22, 2015 06:59 AM
DRG35R
Sep 16, 2015 05:33 AM
AuAltima3.5
Cooling
Sep 13, 2015 10:46 AM
