After 3 years of patiently waiting
Old Jan 24, 2011 | 11:30 PM
usingthejohn's Avatar
SME = Subject Matter Expert
learn something new every day
Old Feb 1, 2011 | 02:54 AM
well, started the install last night. worked on it about 3 hours or so, and just removed the front bumper, intake, undercar shroud things, cats and Y-pipe.
the pictures suck, but forgive me. i took them at 1am.
Old Feb 1, 2011 | 02:56 AM
started more work around 9pm. after an hour of searching teh intranetz, i realized i was using the wrong piping for the mid up-pipe....FML
found the right piping, but still couldn't get it to fit the way it was supposed to. Went back to the pictures i previously found, and realized the stock exhaust manifolds have a heat shield on my car, which was A) not found on the other installs, and B) was never mentioned to be removed on the PowerLab instructions.l
looks like i may need to get a hammer and do some gentle massaging in the morning. looking to gain about 1/4 to 1/2" of needed clearance.
Old Feb 1, 2011 | 03:04 AM
maclovio's Avatar
subscribed. good luck man! keep us posted with lots of pics please
Old Feb 2, 2011 | 11:52 AM
silver g's Avatar
Good luck with the install. I would recomend adding some cooling mods as well...larger radiator and an oil cooler to start. Heat is your enemy with FI and you can never have too much cooling in my opinion.
Old Feb 2, 2011 | 03:01 PM
seymore4's Avatar
m56
I had a plastic bag melted onto my midpipe when I removed it the first time too
Old Feb 2, 2011 | 03:15 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
Good stuff John! Haven't seen you around in a while, nice comeback!
Old Feb 2, 2011 | 05:21 PM
g-adabout's Avatar
Good luck and I cant wait to see the rest of the build!
Old Feb 2, 2011 | 05:38 PM
DailyDrivenCoupe's Avatar
nice! should be a good kit! any more pictures of the manifolds? good luck with the build!
Old Feb 2, 2011 | 06:17 PM
grant long time no talk. ive been lurking for a while, almost got out of the game. but hopefully i can makr my car into one of the better ones here. but that wont be easy as theres tons ofnquality cars out now
thanks!
no pics yet but ill keep updating as time and temper allows
Old Feb 2, 2011 | 06:22 PM
well ran into a rather significant setback. the mid pipe on the kit is hitting the steering knuckle. it looks like i need at least 1/2 to 1 inch clearsnce to get it to sit how it needs to.
with that being said my buddy and i are gonna try and mount most of everything else and thrn try and fab up a new midpipe.
i was getting discouraged, but realized this will be the first of many setbacjs. so ill embtace it as an opportunity to learn
Old Feb 2, 2011 | 06:27 PM
CandlestickPark's Avatar
ill Sedan
Yeah, don't get discouraged. Doing this yourself is going to be a lot of work with bumps along the way.
Old Feb 2, 2011 | 06:39 PM
Heist.'s Avatar
Your taking on a turbo with one of the more complicated cars. having some short piping is not a big deal. I wish you the best of luck, thats a serious project! Just label and take your time. If you need any replacement parts let me know. again good luck!
Old Feb 2, 2011 | 07:20 PM
well thanks for the encouragement. i'll keep at it, hopefully it won't take me too long to figure out the piping aspect of it.
FYI, this is what i'm dealing with. no big deal in the grand scheme of things, and in retrospect. it's what i should have expected when buying a part not truly designed for a sedan.
Old Feb 2, 2011 | 07:26 PM
  #30
GreenGoblin's Avatar
The goblin resurrection
Do you have anymore pics, that does not look correct from when I did a powerlab install for a local memeber. I know you have a sedan, but hold if you can get me some more pics I might be able to help.
