Heat shield for fuel lines
Old Feb 13, 2011 | 05:32 PM
856_reilly's Avatar
Any one know where I can get a heat shield for the fuel lines? I'm looking for the sheet metal kind. I seen arc has one but there a little pricey.
Old Feb 13, 2011 | 07:04 PM
bigc's Avatar
Wings Nation
where are you trying to shield the lines? along the frame / side of battery enclosure or where they cut over at the fuel damper?
Old Feb 13, 2011 | 09:34 PM
856_reilly's Avatar
Right where they come out from the bottom of the car and enter the engine bay. I'm going to wrap them but, I also want to shield them cause there gonna be really close to the turbo.
Old Feb 14, 2011 | 06:15 PM
superchargedg's Avatar
Wrapping them with a quality wrap will be just fine as that is what i did and no problem for over 3 years.
Old Feb 14, 2011 | 06:17 PM
GreenGoblin's Avatar
The goblin resurrection
Yup same here, I had mine all wrapped with saftey wire until I upgraded the lines.
Old Feb 14, 2011 | 08:56 PM
856_reilly's Avatar
Ok.... The guy who is doing the timing on the motor said he has the wrap he uses and it's good up to 1200 radient heat. do you guys think this is good? This is somthing I don't want to play with.
Old Feb 17, 2011 | 05:44 PM
accordfreak's Avatar
I use a heat blanket (the one you can cut up) along with heat tape to tape it up to the frame which completely insulates the lines
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
alessandro
Oct 8, 2015 09:29 AM
invincible514
Sep 21, 2015 07:05 PM
Atwork
Intake & Exhaust
Sep 20, 2015 03:36 AM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
