NATH_19
close
- Join DateMay 2011
- Locationusa
iTrader Positive Feedback100
iTrader Feedback Score(8)
Liked:51 Times in 49 Posts
WOW, the things that I could only drool and look at...
Can I visit you sometime and say hi ??
Silencer_0
close
- Join DateDec 2008
- LocationCorona, SoCal
iTrader Feedback Score(25)
Liked:264 Times in 147 Posts
I finished mounting the assembly, still need to install the GTM pulley.
Gave up for the night when I got stuck on relocating the power steering cooler, gotta figure out how to reroute it's lines.
Looking great man! I am getting my TT kit installed right now, I'm going to back date a build thread. Your engine bay looks sick.
any advice you willing to give on the install? I'm about to install my vortech soon too! everything looks great!
Really Needs a Life
Dustin@StrafeAutomotive
Really Needs a Life
close
- Join DateJan 2007
- LocationRowland Heights, CA
iTrader Positive Feedback99
iTrader Feedback Score(164)
Liked:177 Times in 136 Posts
That a boy :-)
herrschaft
close
- Join DateJul 2009
- LocationCoast
iTrader Feedback Score(18)
Liked:771 Times in 605 Posts
You've got 1 week to tune it
Silencer_0
close
- Join DateDec 2008
Thanks guys! smiLee, a couple things would be, there's 3 small bolts on the front of the engine that they don't tell you to remove to attach the bracket, that's in addition to the other 3 bolts that they do tell you to remove. You'll figure it out once you try to mount it.
Make sure the pipes are rotated the right way. You have to trim the breather hose going to the filter or else it'll kink. I ended trimming like 6".
Having it done by HB will be no problem. I'll either finish the install today or tomorrow and have it tuned on tuesday.
Silencer_0
close
- Join DateDec 2008
Almost there! Just need to tighten everything down, install the GTM pulley, and tighten the drive/cog belt as needed.
Silencer_0
close
- Join DateDec 2008
Thanks Zack!
thank you for the advice! I was also wondering did you get the oil temp gauge or did you get one to monitor your transmission fluids?
