FI Yearly maintanence - what do you do?
Old May 14, 2011 | 12:14 AM
neosoul's Avatar
Just curious what folks do for yearly maintenance for their FI'd cars? I live in the north east, so every spring I pull the car out and perform the list below. BTW, my car is an '04 coupe w/ turbonetics kit at 8lbs. of boost.
Here's mine:
* Remove upper and lower manifold, clean oil - carbon build-up
* Remove throttle body to clean carbon build up (much better idle)
* replace spark plugs (I drive roughly 6k a year)
* Change oil / filter
* Clean air filter with cleaner / re-oil
Old May 20, 2011 | 12:10 AM
Sylvan lake V35's Avatar
How do you get carbon in your intake and throttle body
Old May 23, 2011 | 03:26 AM
beb's Avatar
beb
Do you have any sort of heatwrap on your lines? If you do, another good thing is to either take it off or re-wrap.
Alot of people will use fire-retardant wrap and then just forget about it... Well, if you spill anything that gets onto the wrap, it just soaks in and can be a cause of fire. I have personally seen 2 cars catch on fire from having the wrap catch on fire.
Also, get youre fire extinguisher checked/maintained!
Th611
Oct 27, 2015 03:48 PM
Gip
Aug 24, 2015 05:31 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
