TT setup running out of fuel up top??
Old Mar 14, 2012 | 12:41 AM
Glex25's Avatar
Administrator
I'm currently at Dynosty getting my car tuned and we ran into the same issue.
Have you looked at your fuel pressure gauge to see if it's falling off on the top end.
That was my issue and we found the OEM top seal would not fit snug on my DW pump and the theory was that fuel pressure might be falling out from there. We changed out to the new Walbro 400 and the issue went away.
Old Mar 14, 2012 | 12:47 AM
EverybodyWildOu's Avatar
That was my issue and we found the seal on my DW pump would not fit snug and the theory was that fuel pressure might be falling out from there. We changed out to the new Walbro 400 and the issue went away. Now my issue is that my pressure is slightly higher (even with a CJM Stage 2 and swirl jet modification) than we would want it at idle but we are tuning around it.
Well to be honest I was kind of annoyed when they told me that they threw in another walbro pump because they didn't even ask me... I would've done away with the A1000 and Walbro and got a 340lph or 400 like yourself.
Oh well I just want my car back. If that doesn't fix the issue I'll be pretty livid to the say the least.
Old Mar 17, 2012 | 10:19 AM
nyqueenz's Avatar
custom surge tank like I have.. I replace my Batt up front with a 1 gal surge fuel tank, DW fuel pump and lines and stuff.. pm me is your lookin to go custom like this... I have the walbro in the rear tank that feeds the surge tank up front powered by the DW in tank fuel pump pushin fuel dir to AAM rails and 1000cc injectors.. "I have more then enough fuel"..
mtlruss
Dec 20, 2015 01:51 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
RA102223
Aug 15, 2015 09:24 PM
newg37
Jul 26, 2015 09:32 AM
