Turbo build for 2005 6mt...SpecialtyZ & FCS Fab
Old Aug 25, 2012 | 12:08 PM
buffhulk's Avatar
what size is the downpipe
Old Aug 25, 2012 | 03:46 PM
jninja26's Avatar
I believe 2.5 or 2.75"
Old Aug 25, 2012 | 03:55 PM
jninja26's Avatar
Yesterday:
Old Aug 29, 2012 | 08:40 AM
jninja26's Avatar
Final buttoning up...
Old Aug 29, 2012 | 10:12 AM
buffhulk's Avatar
do you have the jwt oil pan spacer and if so whats the size of the fitting so i can order it for the oil return line
Old Aug 29, 2012 | 02:37 PM
350Z T's Avatar
Why would you keep that small turbo? Should have got a Precision 6266 T4, and had the option of making a lot more power if you decide to build down the road.
Also, why didn't your fabricator get an aluminium MAF sensor bung and weld it to the charge pipe. This way you would not have that big ugly OEM plastic piece of turbing in there.
Old Aug 29, 2012 | 03:17 PM
buffhulk's Avatar
i agree first thing i did is dump the turbonetics turbo....well i acutally still have but im not using it i upgraded to a t4 myself
Old Aug 30, 2012 | 08:32 AM
jninja26's Avatar
No I don't have a spacer. My pan is tapped.
Ummm...In a nutshell, I'm at about $4000 including parts and labor. If I ever decide to get a build engine the cost to upgrade the turbo itself will be the least of my worries.
Most of the system was already built.
I don't have a turbonetics turbo.
Old Aug 30, 2012 | 05:43 PM
Eno's Avatar
Eno
On time and on budget? Off to a good start! When's Dyno day?
Old Aug 30, 2012 | 06:16 PM
buffhulk's Avatar
i do :P i have it here lying around might sell it for 350 on craigslist i dont need it....went bigger anyways your car looks clean and the kit looks great hope you put down great numbers!!!!!
Old Aug 30, 2012 | 06:34 PM
jninja26's Avatar
Thank you. Yes I stayed on the high end of the budget set. There has been several unexpected issues, but SZ & FCS have worked through them so far, flawlessly.
Thank you. I think I will most likely be around 360rwhp. I would like 400, but its just not gonna happen right now.
Old Aug 30, 2012 | 07:39 PM
Eno's Avatar
Eno
Lol issues. Issues happen on Dyno day- you've just had hiccups.
Old Aug 30, 2012 | 07:42 PM
jninja26's Avatar
^haha, thanks for the insight.
Old Aug 30, 2012 | 07:53 PM
buffhulk's Avatar
So fookin true
Old Aug 30, 2012 | 08:45 PM
  #30
Eno's Avatar
Eno
So- when's Dyno day?
