272 Cams with 9.5:1 Compression
Hey guys, just getting into my build on my G and I was wondering if Tomei 272 Cams would be a good cam for my car.
I'm going to be running 9.5:1 compression as I'm going to be turboing. It's going to be run N/A for a few months until I can scramble up some money for the turbo. So is this an okay set up? I'm getting new valvetrain too. Just wondering if this grind cam will work with my compression ratio or am I going to run into any issues?
I run 8.8:1 and I think that's great. 9.5 is probably high-- but I'm SURE someone else would know better than me.
I'm running 600 wheel no stock heads, save the money on the cam and just build the block / buy a turbo kit.
Don't lower your compression and then drive it N/A-- you'll hate it
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
FS[NorEast]: New OEM G35x Compression Rods - Save!!
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
