need good advice
Old Apr 16, 2017 | 08:57 PM
ttwotone's Avatar
Question need good advice
Hello all. I am new to posting on forums so bear with me.
I am currently in the process of building a nearly complete (drop in) motor for my 05 G 6MT
When I say nearly complete I mean that I will reuse some of the basic components as Im sure you figured.
I have already purchased the entire bottom end and it is at the machine shop getting the block bored 20 over and the entire rotating assembly balanced. Here is a list of what I have so far....
VQ35de block Z!
New OEM crank from Z1
Wiseco 8-1 pistons Z1
Eagle connecting rods
All ARP bolts
ACL bearings
Rev-up oil pump Z1
Performance Street clutch with 6 puck disc and midweight FW
I am ordering the stage 3 rev-up heads from Z1 motorsports this week with C2 cams.
The ultimate goal is 600hp plus and be reliable. I think this is completely do-able if everything is done right.
I only drive the car maybe once or twice a week.
There is going to be a turbo involved very soon(after the break in period of the new build)
I was thinking, from what I've read, ID 1000 injectors, Walbro 255 pump with return system.
My questions are..
What have i forgotten?
Are my parts choices reliable?
Transmission?
Axles?
Any good advice would be greatly appreciated.
I will post pics of the car and parts very soon.
Thanks guys for your help
Old Apr 17, 2017 | 10:08 AM
Urbanengineer's Avatar
Probably best posted in the forced induction (FI) section, but this sounds like it's going to be awesome. Bump for someone who might know!
Old Apr 18, 2017 | 05:57 AM
Blue Dream's Avatar
I drove ttrank's car solo
Moved to the appropriate place. Sub'd for this build, looks like it's going to be awesome.
Old May 12, 2017 | 05:41 PM
rcdash's Avatar
You will have trouble keeping coolant and oil temps in check. Oil cooler required for FI. Rest looks fine. Would recommend the Haltech pro plug in unit as your tuning solution.
