Vortech v3 SCI tighten HELP
Old Dec 1, 2017 | 07:05 PM
g35wheels's Avatar
hi guys so i have a sqeaky belt on my new v3 sci blower install and its comming from the serpentine belt can anyone tell how tight its suppose to be and how do i tighten it please?
any help is much apreshated thanks!
Old Dec 1, 2017 | 07:07 PM
g35wheels's Avatar
it only squeals when the steering is in full lock
Old Dec 1, 2017 | 07:30 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Factory spec or a little tighter if its spinning on high boost, are you sure you aren't hearing power steering whine from being at full lock? I HIGHLY recommend buying a belt tension gauge, you can get a cheapo krikit gauge on amazon for like $15. It's a lot cheaper than smoking belts or even worse, over-tightening and smoking bearings.
Old Dec 1, 2017 | 07:55 PM
g35wheels's Avatar
thanks man here is a video so you can get a idea if it helps.
View this post on Instagram
Old Dec 1, 2017 | 08:32 PM
cleric670's Avatar
BANNED!!!
Yeah it just sounds like belt squeal from being too loose, normally you are also squealing at high rpm's though because it's too much drag on the SC pulley.
